RV.Net Open Roads Forum: Hybrid Travel Trailers: Trailer Alignment ????
Open Roads Forum  >  Hybrid Travel Trailers
 > Trailer Alignment ????
Coyote2cool
Denver, Colorado
Posted: 06/20/08 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Dealer told me today you should have an alignment done on your trailer once a year .....
Hmmm .... what are your thoughts on this??
-- Tim --
2008 Chevrolet Avalanche Z71
2007 KZ Coyote 23 CFK
2008 Total nights camping = 27
Just Remember: When everything is coming your way, you're in the wrong lane
Me (37)... DW .... DD (11) ... DD (9)...Dog (1)
Camping photos & Mod's
4HPYCMPRS
Niagara Falls, Canada
Posted: 06/20/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
I am a mechanic! I have my own shop! I personally specialize in wheel alignments and electronics/computerized diagnostics and air conditioning. I do an average of 5 or 6 alignments per day, I have NEVER done an alignment on a trailer! There are NO adjustments (other than shifting the axles)! Don't know why he'd tell you this. ???????????????????????????????????????????????
Mark
How much does he want to charge you for this service?
'08 Chevy Avalanche LT3 6.0L (366hp) 4.10's
'06 Rockwood Roo 23SS. Equal-i-zer/P-3
'06 Honda EU3000iS Garmin Nuvi GPS.
Me ('71), DW ('70), DD ('01), DD ('04).
A wiseman once said "GIT-R-DONE"
'08 nights camped- 28
CAMPING PICS & MODS
Coyote2cool
Denver, Colorado
Posted: 06/20/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
He told me he would try to get KZ to pay for it.
-- Tim --
4HPYCMPRS
Posted: 06/20/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
-- Tim --
Who is gonna do the alignment? Just curious!
Mark
Coyote2cool
Denver, Colorado
Posted: 06/20/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
4HPYCMPRS wrote:
-- Tim --
Mark
I think they would use the company "Bear axle & Frame"......
They are here in Denver ...
Tim
Cybergrunt
Cedar Rapids, Iowa
Posted: 06/20/08 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
My thought is that they are trying to pump you for money.
2001 Coachmen 248TB
5880 GVWR 3768 UVW 4980 GVW 650 Tongue weight
2003 GMC
5.3/3.73
13000 GCVWR 4932 curb 1468 cargo 6400 GVWR 7800 towing 6010 GVW 10340 GCVW
21 years USMC (Retired) (Op deployments: Honduras, Desert Storm, Iraqi Freedom)
SEMPER FI!
Coyote2cool
Denver, Colorado
Posted: 06/21/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Mark
Maybe they are thinking one axle might be more forward than another causing my slightly off center steering wheel when i turn corners?
Remember it only happens when I pull the trailer. Again my Tahoe did the same thing when I pulled the HTT.
Tim
Windy Beans
Chesapeake, Virginia
Posted: 06/23/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I think every other year should be adequate. That way you can have it done when you are in to to rotate the air in the tires and change out the flux adjuster without making an extra trip. Never heard of such a thing!
2002 Dakota V-6
2002 Kiwi 17A
HAPPY TRAILS TO YOU!!
longtrailer48
Kent, WA
Posted: 06/23/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
IF the axles could be adjusted or repositioned, it is a great idea to have them checked. Semi trailers need adjusting all the time from drivers curbing the trailer. It moves one side back and then it doglegs left or right. This is especially important when pulling doubles. They must be aligned to pull straight. IF your axles are not running perfectly straight with each other, then some of your tires are scrubbing the ground at freeway speeds causing overheating. Kaboom! Hmmmm. Anyway, this is much simpler than aligning a steer axle. Use a long straight edge and place along the edge of all the tires. They should touch equally at all points on both sides of the trailer. The front and rear of the straight edge should be the exact same distance away from the frame as well. It will require two people to hold and measure the points to the frame. If it's out, it may require some mechanical assistance to reposition them or a trip to a frame shop. They are very good at this. Just some info to pass along, something we deal with every day in the trucking industry. Hope it helps!
-Jeff
2000 F350 4X4 7.3PSD CC SB SRW Superglide 18K 4" Flowmaster K&N Garrett Turbo Pwr Chp 8-21 MPG
2008 WW FTL4005+5 5th Wheel Toyhauler 48'x102"x13'-6" 3 slides
Coyote2cool
Denver, Colorado
Posted: 06/23/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
Along with the blinker fluid and muffler bearings
All joking aside I'm just trying to figure out why the steering is off when I turn corners.
-- Tim --
