RV.Net Open Roads Forum: Fifth-Wheels: Need Advice on Holding Tanks! That Fell!
 > Need Advice on Holding Tanks! That Fell!
CHV_FRK
Black Jack, MO
Posted: 06/21/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
I will not ever completely fill my tanks until I'm close to my destination for this specific reason. There's alot of bouncing around going on back there with at least 600lbs of water. Good luck
Dana and Natalie
2007.5 Chevy Silverado 2500HD LT SRW CC SB 4x4
2008 Jayco 35RLSA 38'9"
richfaa
Ohio
Posted: 06/21/08 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you were boondocking and no water was avalible at your location it is not a good idea to carry a full tank of anything, Our fresh water tank is 63 Gallons that would be @ 523 lbs bouncing up and down in there. We just had to replace a black tank because of a leak and the bill was 729.00..covered by a extended service contract
06 Montana 3400. 08 Ford F-350 6.4L
Chickie
Slatington,Pa USA
Posted: 06/21/08 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
jsinger years ago my fathers blackwater tank fell off of his 5er while up at Knobels Amusement park CG. That wasn't bad enough he also burned out both axle bearings on the same trip. We never put any water in our holding tanks going to a campground. we just carry an igloo cooler inside our truck for drinking.
Good Sam Life member
GWRRA member
NRA Life member
2002 F350 Lariat SC 4x4 PSD 6 speed,
1993 Goldwing Aspencade/2006 CSC trike conversion
2008 KZ Sportsmen Sportster 35'
1997 Honda PC800, for mileage
Retired and loving it.
jlnix
Georgia
Posted: 06/21/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
I think I'll just keep carrying a full tank of water from home when we boondock and keep enjoying a fifth wheel that's built so that the tanks don't fall out!
1992 Avion 35.5 5th Wheel
2006 F-350 King Ranch
6 liter PSD Torqshift Tow Command
ALBE
Kelowna B.C.
Posted: 06/22/08 12:19am Link  |  Quote  |  Print  |  Notify Moderator
I have only rv,d for 20 years or so .What do you watch for?? Watch you water pump ,it will vibrate fittings loose,caught it before any damage!!Anyone got some hints as to their experiences what to keep an eye on??
mr. ed
Madison, SD (currently traveling the US)
Posted: 06/22/08 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. I've never traveled with the fresh water tank more than 1/4 full. The waste holding tanks are generally emptied before moving on. At 8 lbs/gallon plus the weight of waste material in the black tank, that poundage can add up fast. If a full fresh water tank is needed for boondocking, try filling close to your destination if possible.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
dedbird
Barrie, Ontario
Posted: 06/22/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I know how you feel.
I was driving along HWY 401 (Interstate) in Ontario when a guy pulls up beside me and starts pointing frantically at the the rear of my Jayco Eagle.
I pull over and expect a low or flat tire problem. I couldn't believe my eyes, the water tank had broken through the supports and was hanging about 3 inches off the Hyw on the gas line that goes to the kitchen stove (rear kitchen). The tank pulled all the wiring etc out as well. That was the end of our holiday. I managed to find a RV dealer ( thanks to our GPS) near by and left the trailer for basic repairs to enable me to get it back to our Jayco Dealer.I have pictures but I'm not sure how to add them to this forum.
Our dealer didn't seem to concerned about the problem, even when I explained that the tank could of come out and killed someone.
Typical snail's pace after service repairs punctuated with legal threats got our dealer to repair the RV within 6 weeks.
Jayco took another 3 months to forward a check ($130.00) to cover my out of pocket repairs.
The memories.....priceless.
But another Jayco.....never.
2005 Jayco Eagle 31'
2004 GM D/Max
jdubh2
Central Ohio
Posted: 06/22/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
My tank sagged so bad that I couldn't drain (located on the side) more than half the tank or pump out half of the water since that was also located on the side. I called Cruiser and complained, seems that they agree that putting 2-3 more pieces of angle iron had fixed the problem on other rigs. They also suggested putting a piece of plywood against the tank. Since my dealer is 2 hours away I only take him my rig once a year to fix and he can fix that then. For now I added 4 14 gauge pieces of aluminum angle iron and 1 12 gauge (the kind with the holes pre drilled) and attached it with 1/4 self tapping screws. Took less than an hour once I forcefully drained the tank. I brought it all the way to Maine from Ohio full and didn't see any sagging or any problems. I was afraid the factory straps would break and it would fall.
2008 Toyota Tacoma 4x4 DC V6 4.0L Supercharged 307HP 310TQ
2007 Cruiser RV Fun Finder 250BHS, Equalizer, Prodigy 5500#'s 27ft
