RV.Net Open Roads Forum: Fifth-Wheels: Breaker trips when I use Microwave and AC
 > Breaker trips when I use Microwave and AC
jhawes
Rockport, TX
Posted: 06/21/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I have a Wildcat 2004 fifth wheel and a breaker trips when I use my microwave while my AC is running. Is this common?
Thanks,
jhawes
wayne_tw
South Dakota/Georgia
Posted: 06/21/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
YES, you are drawing too much current and the breaker is just doing its job.
frank henn
jackson, mississippi
Posted: 06/21/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Look in your fuse box, the AC and the Micro are on the same breaker. In mine I have room to add another breaker, and split the two You can get the breakers at any hardware store. Take the other one with you so you can get the correct one
In The Dawghouse
Round Lake IL US
Posted: 06/21/08 08:05am Link  |  Quote  |  Print  |  Notify Moderator
It also depends on where you are plugged in. At home plugged into a 20 amp outlet I can only run one or the other. At a campground plugged into 30 amps I can use both.
Gordon, Susie, Diane, Catie, Susan, Shawn, Annie, Jessi, Keith, Selena.(Yes, 8 kids)
1 Dog Bonnie.
96 Rexhall Aerbus Class A (The Dawghouse II)
Castaway Campers site
Our Photos
fla-gypsy
North Florida
Posted: 06/21/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the world of power management.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Dick_B
Palos Heights, IL USA
Posted: 06/21/08 08:51am Link  |  Quote  |  Print  |  Notify Moderator
other suggestions, don't use the M'Wave (or A/C) and the toaster, or electric coffee maker, or hair dryer, or any other thing that heats up.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
ryanallie1
Magalia, Calif
Posted: 06/21/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
It sounds like your excedding your 30 amp max limit. Check your Microwave, and see what the wattage and amps are for it. Most RV's, can't run the A/C and Microwave at the same time, unless you have a very small wattage, amp Microwave. Your going to have to turn off the A/C in order to use your Microwave. Even if your A/C and Microwave is on the same circuit, it won't do any good to add another breaker, if it still exceeds your max of 30 amps. We are lucky as we have only a 750 Watt Max Microwave, so we can run our 13,500 btu A/C and Microwave at the same time. And still have power to spare. Good Luck. Happy Camping, Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/on board compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 33 Months.
big dave
Soldotna, Alaska, USA
Posted: 06/21/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
You don't say, and I'm guessing that the breaker you're tripping is the one feeding the outlet the RV is plugged into? If so, it's just too much load, and you need to manage your usage while plugged in there.
Dave & Rose C
90 Safari Ivory 34' DP
04 Saturn VUE V6
jauguston
Bellingham, WA
Posted: 06/21/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Frank Henn has the most like idea. Not hard to fix with one of the small double circuit breakers.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
RGordon
Atoka, TN
Posted: 06/21/08 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Best solution is to convert to 50 amp service. All it takes is a new 60 or 100 amp breaker subpanel and 25 ft 50 amp cord. I converted one in spring and overall cost was less than $250. If you are tripping the main 30 amp breaker, then adding additional breakers will not help at all. 30 amps is 30 amps no matter how it is split up. Manufacturers keep loading our campers down with the latest electric gadgets and continue to install these cheap 30 amp services, then if you complain they just say well you can only run one big item at a time. My better half did not like having to cut the a/c just to use the microwave.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
