RV.Net Open Roads Forum: Tech Issues: Stripped Screws
 > Stripped Screws
wohtex
Natalia Tx.
Posted: 06/21/08 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
What do you guys do for stripped out screws in the exterior door panel? The part screwed on the bottom of the exterior door that is used to hold the door open has the two lower screws stripped out on my TT door. The door is a fiberglass panel filled with foam then a metal inside panel so I was thinking about drilling all the way through and putting a backing piece all the way across the interior part of the door for holding power. Anyone have a easier and/or better way??
thanks
Bill
downtheroad
Tumbling Waters, Washington
Posted: 06/21/08 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of solutions..your idea is a good one. Also you can pound a small dia. dowel or a couple of wood tooth picks in the hole...maybe soak them with some glue and then try to run the screw back in. It should hold.
If you want to get fancy, you can try this stuff.
Filler for stripped fasteners.
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Southwind85
Where I Park
Posted: 06/21/08 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Larger screws to tap into the material.
Or take the piece off and raise it about 3/8" so the screws will go into new metal.
The Good Life
handye9
Park City, IL 60085
Posted: 06/21/08 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I would vote for oversized screws.
06 Titan Kingcab
06 Flagstaff 831QBSS
Wife and I
Buddy the Beagle
USN MCPO (E9) Retired (active duty 1973 - 1995)
Check out my mods
Chris Bryant
DeLand, Florida, USA
Posted: 06/21/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I usually bond an aluminum plate to the door, and screw to that.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
crankshop1000
se michigan
Posted: 06/21/08 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Easier to run new drillpoint metal screws near the stripped ones.
robatthelake
Vancouver Island
Posted: 06/21/08 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
JB Weld!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
bacollins
Lawrenceburg, IN
Posted: 06/22/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I have had good luck with plastic screw anchors. Drill the hole for the proper size anchor, fill the hole with sealant, push in the anchor. Install the screw before the sealant dries.
'92 Itasca Sunflyer P series Chevy
'99 Wrangler Toad
'99 Cherokee Toad
'00 Yamaha WR 400
'05 KTM 450 EXC
'92 Honda 750 Nighthawk
Fleet Man
Western WA
Posted: 06/22/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Another option is to use "Nutserts" which essentially are rivets with threads inside. Drill out the hole, install the Nutsert and you have new threads to work with. Back space may be the only problem. They are great for installing mirrors on truck doors or anyplace you need a good, solid mounting on a sheetmetal surface..
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
wohtex
Natalia Tx.
Posted: 06/23/08 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input, I think I will try one of the suggestions before resorting to drilling all the way thru, I'm sure part of the problem is there isn't anything inside the door cavity for the screw to get a bite on and it's just the screw thread on the thin fiberglass panel. The simplest is the tooth picks,or maybe a small plastic anchor that will fit the existing hole, to go to oversize screws I might have to drill out the hole in the bracket so the screw will go in.
From some of the repairs the dealership made and/or told me it's supposed to be that way, it seems I am better off to do it myself unless it's a major warranty item.
Everyone take care.
Bill
 > Stripped Screws
