RV.Net Open Roads Forum: Tech Issues: Refrigerator trips GFCI circuit
 > Refrigerator trips GFCI circuit
jpforest
Michigan
Posted: 06/21/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Dometic refrigerator that runs on 110 AC and propane. It is nine years old. This season my ground fault circuit interrupter kept tripping, and I finally traced the problem to the refrigerator. I unplugged the AC cord and the unit runs normally on propane. Does anyone have any ideas on how to troubleshoot the problem? Or is this a job that should be left to the pros?
USAFBILL
Alabama
Posted: 06/21/08 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the electric element, if so it is not hard to change out and not expensive. It only slides into a cavity along the burner tube..
pulsar
Lewisville, NC
Posted: 06/21/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
