rvcamperontx
Ontario / Texas
Oakman wrote: Jeez, I'm glad I didn't buy a Cougar. All of my vent stacks go all the way up to the roof and vent to the outside. Am I the only one shocked that the vent ends inside the trailer?
Yup, got one under my island sink too. Well guess it's time to trade
up to a Wildcat!
2008 Everest 344J - Quad Slides
2003 Silverado 3500 4X4 Ext.Cab 6.6L Duramax/Allison
2003 Vulcan Nomad 1500FI (MC in tow)
donhov
near Jackson Michigan
Good Sam RV Club
It should be some type of spring loaded flapper inside it. It opens when there is a vacumn and should normally be closed. It sounds like the silicone is keeping it partially open. Go to your local Lowes, Home Depot or Menards and they will have this under $10 part. Get a new one or call your dealer and see if thay have a repalcement in stock. It will probably be easier to just buy one and replace it yourself in the long run is my opinion. They used to be called FHA vent's but as they are more common now I think they go by another name.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
kmh3212
Georgia
I would clean the silicone out and see that the valve moves freely. I think you found your problem.
rick_niagara
Niagara Falls, Ontario, Canada
I have them in my new rig also!
2008 Fleetwood Prowler 235RLS
2005 Dodge Ram 2500 4x2 5.9L Diesel 3.73Limited slip 6speed manual
Pullin' 5ers since 1988....Have a nice day
FisHin2Dmax
Utah
Anyone with a sink that is in an island or not against a wall ( home of RV) will have a vacuum breaker vent. They do go bad from time to time and very easy and inexpensive to change.
2003 GMC HD 2500 CC 4x4 DuraMax/Allison
2008 Sundance 2900MK
byronlj
Loveland, CO/Lake Havasu City, AZ
Oakman,
You might want to check under your sinks. You would have to have a sink location right next to the vent pipe to vent them.
Dave
byronlj
07.5 Silverado LTZ Ex. Cab 3500HD dually 4X4 duramax LMM/allison 6spd
07 HR Presidential Suite 37RLQ
Pickle2
Riva, Maryland,
Good Sam RV Club
estesbubba wrote: I pulled the vent off and there's silicone or something that appears to keep the valve from moving. Should I be able to move the valve by hand? If so, I don't see a way to do it because of the silicone.
It should just simply unscrew; do you see threads on the pipe just below it, the one it is attached to? I cannot tell by looking at your picture if there are any threads on it. It may be that this is a new type of fitting that is glued-onto the piping?!?!
Pickle at Pickldom.
Wife, Deb; Daughters: Brenna(13), Alysson(13)
Dog: Chocolate Chip (English Springer Spaniel) "Okay, in or out, but don't keep pawing at the door!"
03' Dodge, 2500, Long Bed, 4x4, HO Cummins Diesel.
2004 29BHBP Wildcat by Forest River.
doughere
Mooresville NC
estesbubba,
If the device has been damaged by getting silicon on it, I'd replace it. The seal is pretty delicate and the replacement is pretty inexpensive. The ones I've seen on trailers (including Wildcats) are smaller than the ones you see at Lowes/Home Depot, so it will probably be better to get one from an RV store. If you're in a pinch, you coulde cover it with a plastic bag tied to keep the air out while traveling, this would keep it from leaking on the road as a temporary fix. Remove the bag while using the sink.
Good Luck,
Doug
Dave H M
IL
geese bubba, just replace that thing. I would never try to fix something that inexpensive. I grabbed one off the shelf at Lowes the last time I needed one for my sump pump drain in the house. The valve had gunged up after 5 years. I bet the rv one has the same threads as the house ones.
Just ask the pluming guy where are the screw in pvc vacuum breakers or show him the one you toted in with you. If you are the person that has to have an "RV" one go there.
I cannot believe the "knowledge" displayed here in some of the posts.
Lets get er done and have a cold one.
doughere
Mooresville NC
If you do go the Lowes/Home Depot route, check the clearance around your vent first. The Lowes/Home Depot units are significantly larger than the RV style units. Either will work fine, but you might have space/clearance problems with the home style units.
Regards,
Doug
