RV.Net Open Roads Forum: Tech Issues: Changing Out 30 amp Male Plug
 > Changing Out 30 amp Male Plug
chiefward
Covington, GA
Posted: 06/23/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advise. I'm leaning now towards replacing the cord and make an extension cord out of the old one.
2000 Fleetwood Terry, Model 275J EX
2003 Ford F250,V10,6.8L, Super Duty, 4WD, Quad Cab
16K Reese Hitch w/slider
kd8wdave
Middletown,OH
Posted: 06/24/08 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Just cut the old plug off, Lowes sells a connector you can put your cable on and you will have a brand new male plug. The cable goes into the plug and there are three lug nuts to insert and connect each of the three wires to.
cheers
smkettner
Posted: 06/24/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
GSF wrote:
Recommend that if you use the Camco, instead of wrapping your wires around the screws like lots of folks do, buy some ring terminals and crimp them on your wires. It makes for a more professional installation.
I like that idea but I have never seen an amp rating on those ring terminals. Are we supposed to assume they are good for 30 amps if the #10 wire fits?
Learjet
Louisiana
Posted: 06/24/08 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
The terminal ends I used are rated for 50 amps, it is in the info in the terminal packaging.
The Camco plug is nice, except the screws to secure the wire are of poor design. The only proper way to secure them is with a crimp on ring terminal.
2006 Nissan Titan CC with tow package
2006 KZ Frontier 2303P-F
Equal-i-zer
Prodigy brake controller
Yamaha EF2600c Tri-Fuel Gen.
Cowilke
SW Missouri
Posted: 06/24/08 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Cheifward,
Mine needed repair or replacement, at Walmart they had a 10/3, 30', 30A extension for $36. I cut 18" off the female end, and wired the new 28-1/2 foot cord into my TT. Gained 3-1/2 foot over old cord. Wired a heavy 15A male end($8) to the 18", Made a nice 15/30A adapter. I cut the ends off the old TT cord and wired into my shop breaker panel and put a female 30A receptacle with weather cover($18) on the outside to plug the TT in. I was pretty proud of myself, for about $62 got alot done, about thirty minutes to do all the wiring.
chiefward
Covington, GA
Posted: 06/25/08 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Cowilke. That's what I am going to do. I bought a RV 30 amp extension cord off Ebay for $31.00. I'm going to cut the female end off, attach terminals and wire it inside the trailer. The old core with eventually be made into an extension cord. I've never needed an extension core but I will have one if I ever do. Thanks for the idea of making the adapter. Eventually, I'm going to install a 30 amp hookup at my house but that's a future project.
