Canadian Karebear
Saint Albert Alberta
Currently, have no anti-sway bar. Have mulled over it a few times on getting one.
This past weekend, coming home was a nightmare with Truck Suck and windy conditions.
Was going slow (due to lots of rain) (around 90Km/hr) and everyone was passing me (even the trailers!). Yes, I was saving gas, but when a rig passes me, it was hard to keep it on the road due to trailer sway.
My question...
What is the best anti-sway bar and is it worth it for me to alleviate truck suck?
Just wondering.....
Mommy , Skyler , Sammy...the wonder dog
TV: 2000 Ford Explorer Sport 2dr 4WD
HTT: 2004 Jayco JayFeather 18ft Hybrid; Prodigy brake control (with Eaz-lift WD hitch)
See you around the campfire!!!!
Nature does nothing uselessly...
luck would have it
Dimondale (Lansing), MI
With a trailer of that length I would imagine you would be just fine with a standard friction sway bar. $50 out the door. If you are feeling the sway then it is not only justified, it is imperative. In addition, make sure you are not overloading the back of the trailer to take weight off the tongue. Sway begins when you do not have enough tongue weight.
Dave.
2004 Chevy Silverado Z71, Ext. Cab 5.3L
Prodigy Brake Controller
Husky WD Hitch
Dual Cam Sway Control
2007 27' Salem BHBS (Bunk Slide/Super Slide)
Canadian Karebear
Yes, I can see that may have been part of my problem, I threw my son's bike in the door before leaving (it was raining and I was tired..) and it's heavy to it may have adjusted the weight distribution for that.
Thanks for the advice, think I'll have to get the Anti-Sway bar.
Karyn
dodge guy
Chicago, western subs.
Do you have a WD hitch if not you need one along with a minimum of a friction sway control. an Explorer Sport is the 2 door Explorer which has a very short wheelbase.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
goodcruisin
Greenwood, IN
In addition to the other comments I'd like to point out that you stated you were going slow. Without getting into the whole aerodynamic reasons the bottom line is the greater the speed difference is between the approaching vehicle and you the more push-pull is generated. Whenever towing check your rear view as often as possible. When a truck or vehicle towing a trailer approaches do two things. Speed up slightly to decrease the speed difference and move away from them as far as possible. This will minimize the push-pull action created by the compression and decompression of the air front.
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
sharker6
Shelbyville, Kentucky
Get a sway bar but, your always going to get a vacuum when a big rig is flying by you and you'll feel it. Just be prepared.
2005 Xterra off road 4X4, 2007 26' Aluma-Lite, WD w/ friction sway, Prodigy, Yamaha EF2400, 400w inverter, front carrier w/ rod holders, Dish Network
Canadian Karebear
dodge guy wrote: Do you have a WD hitch if not you need one along with a minimum of a friction sway control. an Explorer Sport is the 2 door Explorer which has a very short wheelbase.
Yes, I have a WD hitch, I had it on 4 links from the bottom, was also the first time I tried that (usually have it on 3 links), seemed like the trailer "hopped" a little more, not sure why that was really.
I have an appt with the dealer to install an Anti-Sway bar, they agree that it's a good option for me.
Terryallan
NC
sharker6 wrote: Get a sway bar but, your always going to get a vacuum when a big rig is flying by you and you'll feel it. Just be prepared.
This is true, and a fact of life. but it shouldn't be so bad as to scare you. It truly sounds like you need to redo your hitch, and, or put more weight on the tongue.
As I have always said. If you have sway. Fix it. then put on sway control.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
rlc323
Illinois
BTW. The insructions with your friction type sway bar will tell you to disable it in wet and slick conditions.
2002 Chevrolet Avalanche 1500 Z-71
2002 Trail Lite 8261
Trail-Mate
Frederick, MD
What Brand WD Hitch? If Reese just get the upgrade kit to convert it to a Dual Cam.
1993 GMC Suburban K2500 4X4, 454, 4:10 gears
Hensley Arrow
Jordan Ultima 2020 Controller
Montana Mountaineer Edition 32 PRD
Happy Camping !!
