GA_Campers
GA
I hope someone can shed some light on a problem that only occured today. I have a 1993 28' Allegro Bay. I used one of the 3 light testers today in the rig and lost all power. I have no power either shore or generator. Prior to pulling in the tester I was having no problems. I checked all of the breakers and fuses that I am aware of and nothing is blown. I am wondering if anyone else has had a similar problem, and if so what you tracked it down to. Any help would be most appreciated. Thanks in advance.
Todd
Todd, Kris (wife), Jarrett (7 yo son), Emily (4 yo daughter), and usually Jim and Dee (the in-laws.)
Mandalay Parr
Phoenix, AZ
I would check and reset any GFI.
Did you loose 12 volt too?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
NHguy
NH
Is your tester one that has a little button on it? If so you may have accidentally tripped the GFI (ground fault interrupter) with the test button. You reset the GFI with the reset button at the GFI plug. The GFI plug may be a different one than the one you were plugged in to since they can be wired together. Hope that's it!
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
GA_Campers
GA
I still have 12 volt. As to the GFI, I did think of that and did try to reset it, but it would not reset. I was planning on getting another gfi tomorrow and see if that fixes it. I know just enough to be dangerous to myself when it comes to electricity. In the MH, is all power for the most part on one circuit? I have a main circuit breaker, but I also have 4 other breakers. None of them were tripped. I think I did hit the GFI button on the tester. I was going to unplug it and hit I remember the GFI light going on on the tester, and everything died at that point.
Thanks,
Todd
Tsalla Apopka
Pine Ridge, FL
ONe GFI outlet can feed up to 5 other outlets. So if it pops there could be 5 others out also (usually only 2 or 3 though). Resetting it is not a problem. If there's a short it'll just pop right back out. It should click in and then pop back out if ITS working and there is a problem.
Denny & Karen
Florida's Beautiful "Nature Coast"
Holiday Rambler Traveler 29' (A TREK in disguise!!)
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
GA_Campers
GA
It will not pop back in at all. Also, unfortunately, its not just the outlets that are out, I have no power. A/C doesn't work, nor the Refrigerator. I was about to say the microwave doesn't work, but of course it doesn't if the outlet is in line with the GFI. I am definately get a new outlet tomorrow and see if that is the problem.
Weldon
New Braunfels, TX
Could a breaker be thrown where you are plugged in to shore power? The breakers will be thrown sometimes when they don't look like it. Suggest you turn all breakers off completely then flip back on. MH and shore power.
GA_Campers
GA
Actually, one of the breakers in the house was thrown, but I reset it (was on A/C) and everything in the house works fine. I also reset every breaker, that I can find, in the MH and checked every fuse.
Weldon
New Braunfels, TX
You might try the gfi again to see if it will work. If it does not rmove the screws holding the front plate on and see if the wires inside are connected or if the may be touching.
Wherever I happen to park
There are two kinds of 3-lite testers one has a button, one does not.. IF you have a button and pushed it you have tripped your GFCI as others have suggested
