RV.Net Open Roads Forum: Toy Haulers: XPS Tires on Toy Hauler?
Search only in Toy Haulers
 > XPS Tires on Toy Hauler?
USMC_2651_E5
SOCAL
Posted: 06/24/08 01:35am Link  |  Quote  |  Print  |  Notify Moderator
Hi, new to this forum.
I am having troubles with my carlisle tires on my fifth wheel Forest River toy hauler. I noticed that some of the tread has come off of one of them on my last trip and I need to replace it. After searching this forum I have decided to replace all of the tires and stay away from the Carlisle brand. It seems that many recommend the Michelin XPS Rib. I was wondering if anyone has used the XPS Traction on the trailer. I usually go to remote campgrounds or the desert and think that I would prefer the more aggressive tread. Would the Traction tires be good on the trailer, or does it not matter? Thanks in advance.
P.S. My current tire size is ST235/85/R16 and are rated to approx 3900 lbs @ 90psi.
Road Runners
Tampa Bay, Florida
Posted: 06/24/08 03:53am Link  |  Quote  |  Print  |  Notify Moderator
In my opinion, the standard tread Michelin xps ribbed would be an ideal tire for you. This tire seems to be indestructible. I had trouble with tires on my fivers till I switched to this tire a four years ago. I could not be more pleased. I have no more tire problems.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
PAWildcat
Temple ,PA
Posted: 06/24/08 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Other then for looks, I can't see that the traction tire would be of any benefit. If anything, I would think the rib tire would be a better choice since there is more there to "float" on the ground. But you will have alot of weight regardless.
2005 Ford F-250 PSD CC 4x4
2006 Forest River Wildcat 29BHBP
JIMNLIN
Big Cabin, OK
Posted: 06/24/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
generally for serious highway use a traction tire on a heavy trailer especially on wet pavement can be a bit slippery. The highway rib XPS will handle any terrain you can pull a big TH on. We use highway type tread on our implement trailers on construction sites with zero problems.
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
USMC_2651_E5
SOCAL
Posted: 06/25/08 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input, anyone know of a good internet source for the XPS Ribs?
Power Stroker
Port Charlotte, Florida
Posted: 06/25/08 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
SC_2651_5 wrote:
Thanks for all the input, anyone know of a good Internet source for the PS Ribs?
If you are a member of Sam's Club give them a try. By the way XPS Rib is the bet for your Toy Howler.
Six_on_the_floor
Bakersfield, Ca
Posted: 07/01/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
The Michelin XPS tires are very good, however, they are load range E tires and are rated at 3042# each. If your current tires are rated at 3900# you are giving up 858# of capacity per tire. You may have to stick with a G load rating.
2004 Holiday Rambler 34SKD Presidential TT
1700# Reese Dual Cam
2005 F-350 XLT SRW 4X4 CC long bed 6.0 PSD 6spd manual
SAS!
So. Cal.
Posted: 07/01/08 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Curious Question about the XPS RIBS, These tires are the all steel radials meaning steel belts in the side walls, right? I am guessing that you would destroy these tires if you aired them down to 15-20 PSI in the dunes. Do you guys air them down? I was considering the BFG Commercials for this reason. Am I off base?
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
USMC_2651_E5
SOCAL
Posted: 07/02/08 02:24am Link  |  Quote  |  Print  |  Notify Moderator
Good catch, but I think I will still be ok. My GVWR is 12,000 lbs, so shared over the four should keep me in there. Please correct me if I'm off base here.
USMC_2651_E5
SOCAL
Posted: 07/02/08 02:26am Link  |  Quote  |  Print  |  Notify Moderator
That is a good point. Although I like the desert, I'm don't pull on the dunes because I only have 2wd.
