RV.Net Open Roads Forum: Tech Issues: Little punctures in our Rubber Roof
 > Little punctures in our Rubber Roof
larryandpaula
Vancouver BC
Posted: 06/24/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
I was up cleaning our rubber roof on the weekend and all looked fine up there except for one little section that looked like it had been in contact with something sharp - like a pizza cutter. Now, the holes did not puncture the roof right through - there are just about 6 small divots - like being poked with a sharp pen. I couldn't get up to take a photo before we took the trailer back to storage because it was raining.
The little indents look okay now, but my concern is that over time, they will erode or degrade and create actual holes. Other than keeping an eye on that area, is there anything else I can do to prevent these holes from become worse? Seal with Dicor roof sealant, maybe?
Thanks,
Paula
Larry, Paula and Two Kids (ages 4 & 2)
2006 Dodge Ram Power Wagon
2007 Jayco Jay Flight 20BH
2005 Suzuki RMZ250
trop-a-cal
Palm Coast Fl
Posted: 06/24/08 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Just keep and eye on them. It may be the subroof had some knots in the wood that shrank and formed the depressions.
Caseydon
Simonton, Texas
Posted: 06/24/08 10:26am Link  |  Quote  |  Print  |  Notify Moderator
The best repair for rubber or EPDM roofs is Eternabond Tape. It doesn't take much in the way of preparation, just a good cleaning of the surface, and it does last.
Casey
tvman44
Southwest Louisiana
Posted: 06/24/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Cover with eternbond now for worry free future.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
cabanaman
middleburg florida
Posted: 06/24/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you drug a tree limb across the roof or you had a critter with sharp claws up there (squirrel).Use eternabond patches over the suspect areas and don't worry about them.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
SCR
Full Timer - I'm really not sure where I am
Posted: 06/24/08 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you had a visit from some sort of bird like a flicker, woodpecker, or even a crow.
NCHornet1
Mt. Airy, NC.
Posted: 06/24/08 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I noticed a large ( really large) limb at the rear of my trailer a couple months ago. I looked under the cover and didn't see any damage, so I thinked God and went on!! Well a couple days ago I removed the cover to clean it all up and about 6-8' in there is a large cut in the rubber membrane about the size and shape of a horseshoe. I was sick as I am very anal about my RV. I ran down and looked inside but no apparent water damage. The OSB under the membrane was slighlty damp. I believe the cover kept the water from running directly in the hole and wicked it away. I ordered the repair kit from CW for $40 and right now I have it opened up so it can dry real good before I seal it up when the patch kit gets here. I highly suggest all of us carry a repair kit with us as this could of happened in a CG while on a trip. In your case since it didn't penetrate the membrane I would just check it now and then. If it makes you feel better place a patch over this area, surely can't hurt!!
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
larryandpaula
Vancouver BC
Posted: 06/25/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I didn't even know they sold Eternabond patches! Cool - thanks for the info, everyone!
Caseydon
Simonton, Texas
Posted: 06/25/08 09:38am Link  |  Quote  |  Print  |  Notify Moderator
The Camping World patch kit is clearly not based on Eternabond tape. The CW description says "Use the flexible silicone patching material and adhesive to repair seam tears, gouges and punctures in your EPDM rubber roof." I wouldn't want to use this material because silicone residue is very hard to remove when you want to use something else later, and generally nothing else sticks to silicone, including Eternabond tape.
The $50 price will buy a nice roll of Eternabond.
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 06/25/08 10:34am Link  |  Quote  |  Print  |  Notify Moderator
If you want to get the eternabond tape, get it from these folks, CW sells a 37' roll for more money than Best Materials charges for a 50' roll.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress - Picture's of our old one
