RV.Net Open Roads Forum: Class A Motorhomes: Motor Home Tires
 > Motor Home Tires
justiceb
Dallas, Texas
Posted: 06/24/08 10:11am Link  |  Quote  |  Print  |  Notify Moderator
I need front tires on my Diesel Pusher MH. The size that is on them is 235/80/R22.5. They are Michlien. The tire is very expensive. I was told by a dealer that I could use a Toyo tire that is 255/70/R225. Is that true? Any suggestions? Help please!!! Thanks!
Jim & Terry Bullman
With our traveling buddies Josephine & Skeeter
1998 National Tradewinds
Traveling out of Dallas Texas
Art D
Baton Rouge, La.
Posted: 06/24/08 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Sorry but I don't trust dealers. Not that most are intentionally dishonest, they just are not properly informed some of the time. Try the TOYO website and ask your question there.
Geaux...LSU...
David_in_TX
Grand Prairie, Texas
Posted: 06/24/08 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I would compare the width difference and load carrying capacity. Those tires are 20 mm wider, so they may rub in a tight turn. Toyo makes a complete line of tires, so I am sure they have the correct size, unless your dealer wants to sell you those from his stock. The weight rating should be equal or greater, it is stamped on the sidewall.
Nick Wildwood
Hell California
Posted: 06/24/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I was just wondering which tire store you went to. Keeping the same brand is not important, but keeping the same load rating and size is important not only so your tires don't rub when you turn or when you go over bumps but also so that you can rotate them with your existing tires to make them last longer. (however some motorhomes have different size tires on the front than on the back.) The last time I bought tires for my motorhome we were on a trip and had a blowout. We went to Big O Tires and had great service and good prices. Another time I needed a flat fixed on my Camero and it ending up costing me over $600 when I went to the crooks at Good Year who insisted that it couldn't be patched and that I would need two news tires and alignment.
goodcruisin
Greenwood, IN
Posted: 06/24/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Look in your owners manual and see what size is recommened and stick with that size. Everyone has their favorite brand. Some are more expensive than others. I have Yokohama tires on mine. The ride may be a touch rougher than a set of Michelins, but for the cost difference I'll put up with it. Yokohama partners with Toyo an Continental on the medium duty truck tire. Between those three tires there are tons of them on the road so I feel like I have a good tire. I would recommend using the size on the front as the rear. I went with an all position tire so I could rotate them if necessary.
John (USN Ret) and Debbie
The Paw Pack (Freckles, Stinky & Ranger)
'96 Monaco Windsor 36' DP 8.3L Cummins
Ready Brake w/ Demco Excali-bar
'03 Ford Explorer (Toad)
'04 Honda Insight
'04 Volvo S80 AWD
'74 Dart Swinger Drag Car
14' Boat 9.9 Mercury
pulsar
Lewisville, NC
Posted: 06/24/08 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
chasfm11
Dallas/Ft Worth Areas
Posted: 06/24/08 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Here are a couple of questions to consider:
1. Do you have a spare? If not, what do you think the chances are that you will be able to obtain a replacement Toyo in a reasonable period of time if you end up with a tire problem? When I started searching Toyo dealers across the country, I didn't like the answer that I got.
2. How much risk are willing to take for how much savings? I shopped 4 different brands when I purchased ours. The range was within $300 Even at $1,000 difference, I'd willing to shell out the extra money to stay with something that worked. A blowout on a MH cannot be fun. I've read the stories about the damage done by tires when they blow out and I made the personal decision that the extra money was really like taking out an type of insurance against a blowout. That doesn't mean that I won't but, for my money, I've reduced that odds and that was good enough for me.
We rented twice before buying and had a breakdown with each rental. I go to extraordinary lengths to prevent breakdowns with our MH. I want the absolute best quality tires that I can get my hands on as a way to try not to have a breakdown. 4 Years and 30K miles since buying our tires, I don't regret the decision one bit. JMHO.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
1994 Saturn SL1 Toad, Falcon2 Towbar, BrakeMaster Toad Brake
Sully2
Cincinnati
Posted: 06/24/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
If you switch to the Toyo's...go with 255-80 instead of 255-70. At higher inflation the "80" can carry more weight
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Dynasty40
Hangtown, Northern California
Posted: 06/24/08 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I totally agree with the above posts..one other thing to check, whether you buy from this dealer or not, is the DATE CODE on the new tires. Some tires have been in the dealers inventory for up to three years or more. Usually RV tires die from old age rather than tread wear, and you want the freshest tires on your coach. I changed over three months ago from Firestones to the G670s and I love the ride and comfort of the tires. Good luck with your decision..I know they are expensive...Dennis
Dennis and Debi
Monaco Dynasty Baron 40PFD
Heir Max
membership 1/16/2001, Bay Minette, AL
Posted: 06/24/08 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
The size of tire you can use depends on the width of your wheel. Go to the Michelin site. There will be a chart there. Find your wheel width, and read to the right. It will list the size tires you can use. The width doesn't make that much difference, but you need to stay with the same height. As mentioned above, if you rotate, it could be a problem.
99 Tradewinds
2000 Explorer Toad
 > Motor Home Tires
