rock077
PA
My Goodyear Marathon ST (14in. C rated) tires say max load at 35psi cold. The tire spec. on the Goodyear site says 50psi max pressure. Max. load psi is not to be confused with max. psi. They will gain a bit of pressure when warm so I don't want to put in 50psi cold... right??
The Rocks ( Me, Her, 2 of Them, and 1 Choc. Lab )
2006 Surveyor SV192T
1999 Dodge Ram 1500 5.9lt 4x4
A proud member of The 'One-Ton Rule' Club
Campfire Time
Wisconsin
My manual specifies to run the tires at the max pressure listed on the sidewall. In my case, its 50psi.
Chuck D.
'03 Jayco Kiwi 17a, '03 Chevy Trailblazer EXT, Garmin Nuvi 200 GPS
Photography is my obsession: http://coldwater.smugmug.com/
“Adventure is just bad planning.” - Roald Amundsen
emaav
Hillsboro, Oregon
I too run my tires at max psi (50) per tire sidewall, not info sticker on HTT (replaced/upgraded tire rating)
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
Chuck_S
Broadview Hts, OH, USA
1. All Load Range C tires are 50psi tires, your Goodyears included. Here's the Goodyear inflation chart.
2. Maximum cold tire pressure is just that, max pressure when the tires are cold, before any travel. It is not maximum tire pressure, the tires will have more pressure as they warm up on the road. Never remove pressure from a warm tire. You'll probably find them at 55 psi or so after a run. 50 psi cold is the criteria.
3. The Surveyor SV192T is "over-tired and may be an exception to the "always run max sidewall pressure" procedure. Your tires at 35psi have a tire capacity (for all four) of 5720 pounds capacity which is probably fine for your trailer as it weighs no more than 5100 pounds. The Surveyor placard trumps the "max sidewall pressure" procedure as the tires are much larger than usual.
My '06 Roo 23SS weighs no more than 4800 pounds and has the same tires as your surveyor. I've been running them at sidewall spec (50 psi) with 7040 pounds capacity with no tire issues and they run "cold." I recommend you do the same unless your towing experience indicates otherwise such as worn center tread. (Our placard shows a smaller 13" tire at 50 psi and 5440 pounds tire capacity - typical Forest River slip up.)
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
rock077
PA
Thanks for the info Chuck
I'll have to look at the sidewalls when I get home. I know I have the max load @ 35psi written on them - I must have missed the 50psi load rating.
John3872
Iowa
Mine are listed at 50 psi and I run them at 45 psi.
2001 GMC 2500 6.0L
2006 Rockwood 8281SS
Reese 16K Fifth Wheel Slider
DrawTite Brake Controller
rock077
PA
rock077 wrote: My Goodyear Marathon ST (14in. C rated) tires say max load at 35psi cold. The tire spec. on the Goodyear site says 50psi max pressure. Max. load psi is not to be confused with max. psi. They will gain a bit of pressure when warm so I don't want to put in 50psi cold... right??
After checking my sidewalls I have 14 in. B rated Marathons - The correct inflation is 35psi.
