RV.Net Open Roads Forum: Fire Escape ladder - do you have one?
 > Fire Escape ladder - do you have one?
Mountain Mama
TX
Posted: 06/24/08 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
And if so where did you get it? I told DH if I had to use the bedroom exit window, I would end up with a broken leg or worse! Although, I realize this is better than the alternative in case of a fire, I think I'd feel better having the ladder handy.
2003 Holiday Rambler Alumascape 34RLT
MAJESTYPOINTERS
MONROE, MI.
Posted: 06/24/08 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
What type of coach do you have....My rear ladder is right next to the window...never really though about it till now but that would work to climb down on if I had to use the rear window exit...and it is always their. JMO
chickadee
N.C.
Posted: 06/24/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
We don't have a ladder, but do have a fire extinguisher laying on the floor beside of bed. Of course it's on DH side.
My plan, while DH sweeps and spray. I will grab towels, wet them to wrap around our heads as we run. Plus a wet towel to wrap around my doggie. If it's to late to do any of this, were out the window and will deal with the end results later.
Hubby Me
One Spoiled Maltese (Puddles)
03 Ford F-250 Super Duty Super Cab SB 4 x 4
06 Rockwood 5th wheel 8283SS (Forest River)
Exocet
Central NY, USA
Posted: 06/24/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
I've always wondered how you get your feet out first? Where our escape windows are located, you almost have to go out head first. Which means landing head first when the bottom of the window is 5 ft off the ground. I guess it beats the alternative, although a broken neck isn't too high on my list either.
2008 Nissan Titan SE, Crew Cab, 4x4
Long Bed, Big Tow
2006 Rockwood 2501
Equal-i-zer
Tekonsha Prodigy
Smokyjoe
Cashiers,N.C.
Posted: 06/24/08 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I keep my roof clip-on ladder on broom snaps under the window. It hangs nicely out the window from the hooks made to hang on your roof ladder. I don't no,until the time comes ,which way I would go out,head first or feet first ,if I have enough time. At least it gives you something to hold on to going out.
Smoky's Den
2001 KSO1 Travel Supreme
PT Cruiser Toad
Wheaton Terrier dog
Hurricaner
Hurricane Utah
Posted: 06/24/08 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
By the time you get that ladder set up at least one of you will probably not make it. These things go up fast, get out anyway you can, don't worry about a ladder or a broken leg.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Damon owners forum
Southwind85
Where I Park
Posted: 06/24/08 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Whoever designs emergency exits in most of the RV's that I've seen obviously totally ignores reality when they have their pencil out. My escape window is in the bathroom. It's the classic small window with a 6ish foot drop to the ground with no hand holds. Just a small hand hold outside above the window would make it useable but nooooooo, can't have that out there for some reason short of installing one myself. Just 6 feet away and far more convinent for a fast egress is the back window (does not open) that happens to have a readily available roof ladder right there to grab and descend.
In my RV the plan is to forget the silly time consuming dangerous head first to the ground escape window. I'm going out the much larger back window and taking the ladder to the ground under control. In the event a quick egress is required, it will be much MUCH faster and far safer going out the back via the ladder.
The Good Life
wny_pat
Western NYS
Posted: 06/24/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Sam said it well!! I've never seen a motorhome go, but have seen a "mobile home" go up. Went extremely fast. There was no one in it, but if there had been, they would not have gotten out. Extremely hot fire with lots of toxic smoke. Just bail out that window and don't worry about breaking a leg.
tom_kat
way upstate new york/lake george area
Posted: 06/24/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
breaking out our back window with the fire ext and using the ladder would probably be faster and safer then the exit window with over a 6 ft drop on your head not thought out very well at all.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
RJCorazza
Maryland
Posted: 06/25/08 04:22am Link  |  Quote  |  Print  |  Notify Moderator
Don't count on breaking out automotive tempered glass, which is what is on my rig and likely most (?). Tempered DOT glass will be labled as such in a corner. You can go at it with a sledge hammer and and have a surprisingly difficult time. Better to have some type of pointed device like a center punch available.
