RV.Net Open Roads Forum: Travel Trailers: Water Heater Whoosh
 > Water Heater Whoosh
Mikesr
Lebanon Pa
Posted: 06/25/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Our water heater makes a loud "Whoosh" sound when it fires on LP. You hear the clicks then the "Whoosh" sometimes it does not fire on the first try. It has also needed to be reset a couple times. Our last HTT had the same water heater but never made this sound. Is this normal? We have not had to have this TT back for warranty work yet, could this be our first? So far it is working just worried about the "Whoosh".
Mike and Donna
2005 Chevy 2500HD
2009 Flagstaff 831FKBSS
waflhtrider
Pierce County Washington
Posted: 06/25/08 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Sounds normal (without actually hearing or seeing the flame) to me. Next time you have it by the dealer (just stop by if your int he area) have them take a look at the flame. Could just need an adjustment.
WAFLHTRider Ryan(W7SFO)& Beth Pierce County WA.
Nights Camping in 2008 52
NWSpring Rally 2008 Pictures.
My Web Page
My Myspace
Pictures
Old photos
2005 Dodge RAM 3500 Long Box 2WD Quad Cab HO 5.9L CTD
2006 Carriage Cameo 35KS3
2004 HD FLHTI
My Blog
Bduece
Massachusetts
Posted: 06/25/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
My trailer's water heater makes the same sound. I hear click, click, click, woosh and it's on. The chamber needs to get the right mixture of propane and air before it fires up. I wouldn't worry about it unless it goes on for more than 30 seconds to a minute. Mine does it for maybe 5- 10 seconds.
Bill
2006 Dodge Ram QCSB 4x4 hemi
05 Forest River Cherokee 28A+
nny12972
NY
Posted: 06/25/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
And was the old WH as close, or in a location where you couldn't hear it as well?
Personally, since I'm the gas man, the HW man, the refrigeration man, I LIKE being able to hear things fire up! I don't wanna' become the fireman---knowing how things are operating keeps me happy!
J
NCHornet1
Mt. Airy, NC.
Posted: 06/25/08 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Your ignitor may have to be adjusted if it isn't lighting on the first try. After the air is purged it should light the first time every time. The woosh is normal as the gas turns on for a brief second before it inites so the woosh is this pocket of gas igniting.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Hornet28BHDS
Parker, PA
Posted: 06/25/08 08:01am Link  |  Quote  |  Print  |  Notify Moderator
That sounds normal. It's just the water heater igniting.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
javaseuf
Southern Cal
Posted: 06/25/08 10:27am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like there may be spider webs or other debrise in the flash-tube.
When running, you will hear this "whoosh" but there should be no delay in ignition and/or a big "pop" or "whoosh" on initial start-up.
This scenario usually indicates a delay and build-up of raw propane getting to the ignitor due to blockage. Blowing air through the tube from the venturi end should cure the problem. DO NOT blow air from the upper-end of the tube. This could possibly blow dirt into the orifice.
The only other issue could be a defective, slow-opening gas valve.
* This post was edited 06/25/08 11:32am by javaseuf *
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
mobeewan
Hampton, Va
Posted: 06/26/08 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Whooooooosh and a little whistling for mine when it fires off.
