gandl2
Palm Springs
We are considering buying a mid-level diesel pusher. One consideration is how well insulated are the walls/floors/ceiling. It doesn't appear as though the manufacturers publish the R value information for their coaches. Does anyone have any specific recommendations by brand on who has good (or bad) level of insulation in their motorhomes?
Rich D.
New England
I have camped in 10 below zero temperatures with our Wanderlodge and it stayed a comfy 70 degrees inside. I can't say what the R values are but the AquaHot (and the propane furnaces in our last Bird) kept the coach comfortable.
Rich D. Wanderlodge LXi 43'
Briteskys
Mesa, AZ
Our Beaver seems fairly well insulated although I have no idea of the R values AND considering the amount of glass area.
I think having a heated basement contributes a lot keeping temps pretty even and although we've not been in extreme cold, the Hydro Hot has done a good job so far.
Cooling has been sufficient -- we're 40' with two 13.5 btu A/C's.
Your question is a good one as these coaches certainly aren't built like a stick house.
'02 Beaver 40' Patriot Thunder
CAT C12 455hp
Jeep Grand Cherokee
Ron & Jane 2007 - 08
DUTCHSTARWEST
GREECE NY USA
You can find out much of value about any coach by reading closely the sales lit.. Next time you are on the net or at a show, gather up the sales lititure and look for the "r"values.. This worked for us and was a factor in shopping for a "DSDP"..
wny_pat
Western NYS
I have read great comments on Tiffins staying warm in cold weather.
Lug_Nut
Newmarket , Ontario, Canada
Newmar does and always has. Generally their DP's are Walls R-11, Roof R-16, Floor R-16 and basement R-4.
'07 Newmar Essex 45' ISM 500 4 slides
cmiller006
canton
R value in a sidewall has no meaning. Once you cut a hole in the wall and insert a window you have lost all R value. If you have dual pane windows you have around an r-4-6 value.
Deen
Vancouver, WA
cmiller006 wrote: R value in a sidewall has no meaning. Once you cut a hole in the wall and insert a window you have lost all R value. If you have dual pane windows you have around an r-4-6 value. Still better to have high R value overall than low!!
Our Newmars have always been easier to keep warm or cool depending on what was needed. When we ordered our 2002 they had an optional roof insulation package that cost about $100. Well worth the cost too!! We got it, it might be standard now though.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
KOG
Winterville GA
Dual pane windows have about a 1.4 R value. Windshields (single pane of course) are 0.7. So it really doesn't much matter if you have wall insulation if the windshield isn't somehow blocked off or isolated from the rest of the coach.
Aridon
SE Florida
Check out Newmars. Excellent insulation compared to some others.
edited 07/02/08 02:41pm by an administrator/moderator *
