RV.Net Open Roads Forum: Towing: Break Away Cable
Search only in Towing
Open Roads Forum  >  Towing
 > Break Away Cable
Scot
Maryland
Posted: 06/26/08 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Here is where I hook mine on the 5er..
Hook to this clip
Scot & Ann
*NEW* 2008 Silverado 3500HD LTZ CC Dually Duramax/Allison
2005 Everest 343L
Hidden Hitch 18k
My Photos
marty649
Waycross GA (okeefenokee swamp)
Posted: 06/26/08 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Jacdanboy wrote:
Here is how I hook mine up
here is another post on the subject.
This the same way I connect the cable.
2005 Dodge 3500 Quad cab CTD Dually, Laramie, G56 sbc con-ofe, GPS-NAV, Sirius, intake and exhaust, Gauges, 100 gal aux fuel tank, Rokktech, Quad box, Pacbrake, 85,000mi
2000 Gulfstream Seahawk, Sat TV, Solar, 6.5kw gen, Washer/Dryer
2001 Roadking
dodge guy
Chicago, western subs.
Posted: 06/26/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Me too!
In the unlikely event the whole hitch seperates from the TV, the brakes will still actuate.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
Campinfan
Washtenaw County, Michigan
Posted: 06/26/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
I did like the above picture, but I painted mine black.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
the hangman
Green Bay, Wi
Posted: 06/26/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Just last week there was a thread (I think on the popup area) where the entire hitch fell off a mini van (IIRC) - luckely the camper ran off the road and into a ditch without hitting anything else.
It can happen ... I connect my cable to my rear windshield wiper. It may not be the strongest place - but I have tested it and the breakaway switch pulls out somewhat easily. I think I will try to find a better place though ...
Jeff
2005 Fleetwood Valor
2007 Nissan Pathfinder
LIKE2BUILD
Mt. Zion, IL
Posted: 06/26/08 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Jeff
I wouldn't trust that if it were me. I use the carabiner method as well with it hanging from my bumper, completely separate from the receiver. If the hitch entirely fails, the carabiner is strong enough to hold the cable and activate the brakes.
KJ
2002 Jayco Qwest 324G
2004 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
1981 Seastar 18' Runabout
1996 Polaris SLT780 Waverunner
3 Wonderful Sons (9, 3, & 1 year)
1 forgiving wife!!!
beemerphile1
NE Ohio
Posted: 06/26/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use a short length of chain bolted to the frame and running between the bumper and receiver. I attach to that with a clip similar to what is on a dog chain. If the entire receiver comes off my brakes will activate.
I also read that the brake cable should be of the correct length that even if the safety chains hold, the brakes will activate. If the hitch fails but the safety chains hold it could rip out the umbilical cord making it impossible for you to activate the brakes manually.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
the hangman
Green Bay, Wi
Posted: 06/26/08 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
LIKE2BUILD wrote:
Jeff
KJ
Ha - now that I read my previous post - it sounds really, really bad
The rear wiper mount is very sturdy - I'll bet it could take a good 100 pounds of pull. The break-away switch probably takes 2or 3 pounds of force to pull out.
I purposly connected the brake-away cable to the wiper mount with a small aluminum carabiner - I know the carabiner would fail befor the wiper pulled out if I did something really dumb (like unhook the trailer and pull ahead while forgetting to unhook the break-away cable) (no, I havn't done it)
On my Jeep that I sold last year - I had mounted an eye hook below the bumper for the break-away cable.
My new Pathfinder has the factory receiver permantly mounted to the frame/bumer - so I looked for some spot the was totally seperate from the hitch area.
Jeff
 > Break Away Cable
