esbeasley
Eastern Shore Maryland
Just installed Ride Rite's on my Chevy 2500HD and would like to go to a single point airfill valve. Does anyone know of a part number for/do they make a single point airfill ?? I think an inline "t" would work using one of the existing valves. just need a part number: local shop is stumped.
Having trouble with air loss. Have pulled the bags, inflated and checked in a water trough: leaking around fitting into the bag. Cranked down the fitting as tight as I can go: still leaks. Considering pulling the fittings, cleaning the thread and reinstalling using ???? Locktite, pipe sealant, any suggestions ??
'06 Chevy 2500HD LT;D/A;CC;4WD
2009 Big Horn 3580RL
mikehart92
Oklahoma
Are they new. If so, why keep fighting them. If they leak, get them warrantied.
Mike
Boilermakers Local 592
2005 Chevy 2500HD.............6.6 D/A, 4x4, Crew Cab
CTD2003
Arizona
I put teflon tape on mine and had no leaks.
Engineer9860
Eagle Scout dad
As far as the single point air fill, any type of air line tees, and air line tubing should be available at any place that sells parts for OTR trucks that use air for brakes, and suspensions.
If what I am getting a mental picture of is true, you are probably looking at $10.00 worth of brass fittings, air line tubing, and such.
Look in the phone book, you should be able to find a heavy truck parts dealer in there, 98% of these guys will have experience in fabricating custom applications, and sourcing parts for same, so a project like yours should be a breeze.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
glsurrat
Virginia
I paid $8.00 for a T fitting that fits the air lines that came with the Ride Rites kit. Bought it at an RV shop that works on motorhomes as well as trailers.
For the leaking bag, send it back and get a replacement.
Greg
Full-timing and soon to be retired US Navy Master Chief
Enjoying Champagne on the King Ranch!
'06 King Ranch F-350 Dually Diesel 4x4 Long Bed Crew Cab w/ Tow Boss
'07 Champagne Edition NuWa Hitchiker 3 axle 4 slide 37CKRD /w TrailAir all around
ronfisherman
SE Michigan
This is probably more than you need. Here is a kit sold at Summit Racing. You only need the Tee in center of picture.
You should not have leaks. My system has held pressure for over a month since putting it in.
Saf-TTE tire monitor
Airstreamer67
Pineville, LA USA
It sounds like the leak is coming at the source of most airbag leaks: the fittings. Like said before, use teflon and retighten. That will probably stop the leak.
Scot
Maryland
1/4" "T" from Napa...
Scot & Ann
*NEW* 2008 Silverado 3500HD LTZ CC Dually Duramax/Allison
2005 Everest 343L
Hidden Hitch 18k
My Photos
