RV.Net Open Roads Forum: Towing: Tires on HOT pavement
Search only in Towing
Open Roads Forum  >  Towing
 > Tires on HOT pavement
cujo1950
victorville, ca.
Posted: 06/25/08 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
We're leaving on vacation this weekend and are crossing the Mojave Desert thru So. Ca. and Arizona. The forcast is up to 115 degrees during the day. My question is would you still fill the tires up to max. 80 psi, or drop a few lbs. for expansion in this extreme heat. I understand the cold pressure should account for normal heat expansion but at these extremes????????
Steve
2006 Dodge 2500 CTD, Auto
2006 Pilgrim 295RLSS fifth wheel
Cox89XJ
Tennessee
Posted: 06/25/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I would air mine to max.
smkettner
Posted: 06/25/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Air them to the max tonight when cold.
silverfoxn
Georgia
Posted: 06/25/08 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
The question should be; How much damage to the tires can I expect if I drive on them before they reach their "normal pressure" if I don't fill them to their "cold pressure" before dirving? I guess that you could stop and let some air out when they get hot and then stop again and add more air as they cool down. Mine call for 80 PSI cold and that's where I put them. If you are really worried about the heat, drive at night. I do sometimes.
Jesse & Karen Norris with Kirby our chow-chow
2005 HitchHiker II LS 29.5 LKTG
2005 Dodge Ram 2500 Turbo Diesel
Martinez, Georgia
Fulltimers
Anywhere, USA
Posted: 06/25/08 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Just fill them to the recommended cold pressure for your load and don't worry about it. The tire manufacturers plan for these conditions.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/25/08 11:45pm Link  |  Quote  |  Print  |  Notify Moderator
I lived in Phoenix for several years. The tires don't mind the high temperatures at all. Fill them as you normally would and drive on them as you normally would.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
BurbMan
Long Island, NY
Posted: 06/26/08 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Always start out by airing the tires up to the max psi when cold (prior to 7am). Note the ambient temperature at the time when you check the tires.
Temperture then changes at 4 critical times each day, 10am, noon, 2pm and 4 pm. Best way to handle this is to take a break as close as possible to these critical times and assess your tire situation.
Using a digital tire gauge, record the current psi for each tire. Using your infrared thermometer, record the temp of each tire in degrees F. Using a pair of calipers, measure the section width of each tire at the widest point along the sidewall. Compare the measured sidewall width to the spec width provided by the tire manufacturer, and if increased by more than 3.5%, then possible pressure adjustment is warranted. Calculate both the temp rise at the tire and also the psi increase from the baselines noted when cool. If the square root of the sum of the differences exceeds the section width variance by more than a factor of 1.0, then adjust the pressure on a per-tire basis in increments of 0.5 psi until an acceptable ratio is obtained.
Or, just leave them at 80, they will be fine.
bdougt
Now Louisiana, Eventually Michigan
Posted: 06/26/08 06:57am Link  |  Quote  |  Print  |  Notify Moderator
DUDE - that is a hoot!!!! Good One.
Brian, Donna, and Ted the dog.
2006 Dodge MegaCab 2500 4x2 CTD 48RE 3.73 gears
Firestone AirBags - Reese with Slider
2006 River Canyon 34KSTSO - TrailAir Pin
Mark Kovalsky
About 60 miles SW of Detroit
Posted: 06/26/08 07:51am Link  |  Quote  |  Print  |  Notify Moderator
silverfoxn wrote:
I guess that you could stop and let some air out when they get hot and then stop again...
..to change the tires that blow from underinflation.
Mark
2002 Ford E350 van connected to a 1998 SunnyBrook 33 FKDS travel trailer by a Hensley Arrow hitch
Former Ford Automatic Transmission Engineer, 1988-2007
Steveque
Central California
Posted: 06/26/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
If I may make a suggestion. As long as you are in California, the maximum tow speed is 55. I doubt you will overheat your tires at that speed.
I just finished a 6300 mile tow. While going through Texas where normal posted speed is 80, I witnessed several trailers alongside the road with blownout tires. Each of them had passed me at or near 80 mph. I maintained a sensible 60 mph everywhere except California. I never worried about the heat and it was warm - 100+ on several days.
Steve Quesenberry
Central California
