RV.Net Open Roads Forum: Folding Trailers: What size tarp?
 > What size tarp?
Hornet28BHDS
Parker, PA
Posted: 06/26/08 10:16am Link  |  Quote  |  Print  |  Notify Moderator
A huge tarp is what you will need!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
mobeewan
Hampton, Va
Posted: 06/27/08 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Yes they are heavy (due to the weight of the pipes) and you will need a truck for carrying the shelters. They also take a while to set up, but I camp for 4 days at a time and it is well worth the trouble on a rainy weekend and provide a lot more shelter than a bag awning.
The connectors are carried in a cardboard box inside the pup. I made 4 PVC pipe carriers from 4 inch PVC pipe. Each carrier holds 6 Pipes and loaded weighs about 40 to 50 lbs. I can carry them on my shoulder one at a time to load and unload from the truck. I strap 2 carriers on each side of my truck rack with my canoe in the middle. At the campground I leave the carrier strapped to the reck and open the end of the carrier and slide the pipes out to set up.
I don't use the pup for winter camping, so snow is not a problem.
thatguy1967
Springfield, Missouri
Posted: 06/27/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Good grief man - if you're going to do that just ditch the pop-up altogether. Just buy one of those expedition tents from Cabela's - you won't see the sky either way you go.
2002 GMC Sierra 1500 2WD Ext Cab, 5.3L, 3.42 axle
2006 KZ Coyote 23CMS, Equalizer Hitch/Voyager Brake Control
thatguy1967
Posted: 06/27/08 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Vapor_Trails wrote:
Why not something like this. You can get them anywhere.
Envisioning a campground full of these....ugh.
campingrandma
South Carolina
Posted: 06/27/08 11:10am Link  |  Quote  |  Print  |  Notify Moderator
There are some private "campgrounds" (and I use that term loosely) in NC where these are erected permanently on all the sites UGH is right!
JohnJoanW
Zephyrhills, FL
Posted: 06/27/08 11:13am Link  |  Quote  |  Print  |  Notify Moderator
We use a 20x30 ft white one to completely tarp our Fleetwood Niagra because we are out for seven months this year and six last. It is the first thing to go up and the last thing that comes down. We put it over the camper before we lift it and tie down the four corners to keep it from blowing off after it is lifted. When we break camp, we lower with the tarp still on and fold it in half to keep the dirt and moisture on the inside of the tarp. The process is repeated at our next location. The tarp protects from the sun, sap, etc. and allows us to put it down dry after a rain. It also provides us with extra shade because one side of the tarp is even with the end of the awning and extends about six feet from each side of it. We use expandable poles on the two awning side corners and two taller ones on the back side to lift it up so we can see all around. Using a tarp is not without its drawbacks. Any tarp you can put up, the wind can, under extreme circumstances, take down. We have experienced 40 mph winds, which proved to be a challenge in keeping everything in place. We were successful, but the tarp is quite noisey in heavy winds, which makes sleeping difficult. When we know heavy winds are possible, we drop the poles and secure the corners to the frame on the camper. We use tent spikes that we got from Walmart in hard ground and sides, and the screw in stakes for tying out dogs in softer ground for the corners. Also, remember that unless you put a large fan on your roof to exhaust the hot air from the A.C. you cannot run it with a tarp over it. We put pvc poles in the bike racks to lift the tarp up off the A.C. and bungee a fan to the bottom part of the rack. There are other pictures on Picasa Web, at http://picasaweb.google.com/johnjoanw If you are only going out a few times a year, I think your best bet is to get a good screen room.
* This post was edited 06/27/08 11:19am by JohnJoanW *
Be Blessed!
Andrew in Canada
SW ONtario Canada
Posted: 06/29/08 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
We saw this for the first time (at a camp ground) just last month.
One group had two of them back to back, made their own pavilion !
UGH ! was simillar to my description as well !
Andrew
2006 Palamino 4123
2008 F150 XLT SC 5.4 4x4
1DW 2DD
1BC ( border colllie )
PattieAM
Maryland
Posted: 06/30/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I can understand the concern for closing the PUP with dampened canvas and not being able to dry it later....I carry an electric leaf blower (giant hair dryer) which really helps rid the canvas of excess moisture.
 > What size tarp?
