I've found a lot of amazing things in the not-easily-visible spaces of our new Icon. This is a shot of the space behind the radio/dvd player. Aside from the fact that it looks like h***, I've got a specific question.
The bright white rectangle to the left of center would appear at first to be a standard RV wall outlet. But the holes for the prongs of a plug aren't punched out. It's being used as a junction box to connect two segments of the yellow romex. My question is: Is it permitted by code to have a junction like this just hanging off the wires, or does it need to be physically secured to something?
edited 06/26/08 05:25pm by Wayne Dohnal *
Secured to the wall I would guess. I never left a junction box hanging by the wires. Looks like anything goes in an rv, from the looks of your picture. That wiring has the look of what I would call Mr Butch an his friend Mr. Hack. For short butch an hack. Now you can see why we need local inspectors.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
Not sure of code, but if it is an "rv" junction box with push in connections, get rid of it. The outlets in RV's tend to melt from loose push in wires; this could be the same type. An accident waiting to happen...
Mount a proper j box on the cabinet wall and connect the wires according to NEC code. (wires twisted with wing nuts)If I were doing it, I would also arrange the romex neatly and clamp it in place. I don't blame you for asking! VK
That is just wierd. Guess it is quicker and cheaper for the RV manufacturer to use on of those than mount a proper J-box. The one upside to the contacts on what you have is that bumps and motion will have zero impact on the integrity of the connection.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
That is a new type 120 wire connector and is similiar to a extension cord type connection. The difference is it is built for Romex and has locking tabs to hold the connectors tight. NO, they are not supposed to be mounted on secured. They use them on some OEMs to NOT have to have junction boxes or run a dedicated 120 romex from the breaker panel to the outlets or appliance outlet. Yes, it is a cost saver, but is UL and RVIA approved. Doug
Quote: Not sure of code, but if it is an "rv" junction box with push in connections, get rid of it. The outlets in RV's tend to melt from loose push in wires; this could be the same type. An accident waiting to happen...
Better get rid of every RV outlet in every RV produced in the last 15 years... because they all use those "self contained receptacles".
Wayne I don't think you are going to find anything in the NEC that specifically says that a splice box has to be secured but I could be wrong. From an inspection standpoint it could be turned down because it is just not a neat installation.
My old 95 Gulfstream class C had a lot of that sloppy wiring but I never had any problems with it. The good news is it is 12 gauge wire and it would be an easy place to tap another outlet into. Any Idea what it feeds?
Quote: That is a new type 120 wire connector and is similiar to a extension cord type connection. The difference is it is built for Romex and has locking tabs to hold the connectors tight. NO, they are not supposed to be mounted on secured. They use them on some OEMs to NOT have to have junction boxes or run a dedicated 120 romex from the breaker panel to the outlets or appliance outlet. Yes, it is a cost saver, but is UL and RVIA approved. Doug
Doug, I'm familiar with what you are referring too but that is not what this is. It is just a self contained receptacle with a blank face. But I believe you are correct that those new spice kits don't need to be secured so there is no reason to believe this does.
