RV.Net Open Roads Forum: Truck Campers: New Honda
 > New Honda
scotto0609
babylon,ny
Posted: 06/26/08 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just tried my new honda 2000 out that I got in January! It ran both my carrier 11,500 a/c on low cool and my frig while still on econo mode!!!! Yea me!!!! And I can store it in my empty gen compartment.
scotto
AZCampinfool
Gilbert, AZ
Posted: 06/26/08 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
scotto, the Honda's are nice little units. I have two of them and parallel them together. I would get an a/c voltage meter to plug into your camper so you can see what's going on. The Honda sounds like it is doing fine now, but things change when you go up in elevation or the converter/battery charger kicks in. With a meter you can tell what is going on all the time and would enable you to avoid any low voltage situations from too many current draws on the genny. Camping world sells this one pretty cheap. a/c votage meter
Me, my wife & 2 DD's, plus the yellow camping labs
2001 GMC Sierra 2500HD CC 4X4 8.1L big block/Allison
2006 Montana Mountaineer 319BHD w/Trailair
IAFF-Local 2260 Mesa, AZ
Rvndave
Medina, Ohio
Posted: 06/26/08 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
I also twin mine when running a/c, but have used one to run the 13,500 btu a/c. The single gen was able to keep the voltage up. I had to run the fridge on gas an reduce other loads.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
joe_jeep
hazel park, mi
Posted: 06/30/08 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
my new eu2000i i bought in feburary ran my 13,500 btu ac no problem and the tv and lights too. its gotta go to the shop for repair already though. wont run without the choke on?
2002 f250 sd shortbed supercab 4x4 lariat v10 3.73
2005 travel lite 890sbrx w/ac
1997 wrangler 4.0L nv3550 4.56 locked & lifted
rjsurfer
North Carolina
Posted: 06/30/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
When the gen won't run unless the choke is on means that the jets are a bit clogged....just put some carb cleaner through it and use Stabil in the fuel when storing.
Ron W.
03 Dodge 2500 SRW,SB,EC
2008 Keystone Cougar 245RKS 5th Wheel
DRZ-400SM
DL-650
 > New Honda
