RV.Net Open Roads Forum: Class A Motorhomes: Diesel Soot Removal???
 > Diesel Soot Removal???
franknsandy
USN-Retired, Skippers, Virginia
Posted: 06/26/08 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
1st,
OK, I had a cracked maniford and the exhaust of my DP was all over everything. It seeped into the inside of the coach also. I have got it almost all cleaned up but still have a couple areas that I need some input from you guys (and gals).
The front roof vent must have sucked the soot out or through it while driving and all around the vent is black. It is a fabric ceiling. I used some carpet cleaner in a foamy aerosol can with a built in brush. It worked great on the floor, but was terrable on the ceiling.
Anybody know of a cleaner that may remove the soot. I know about Oxi-clean and it is just OK. Any other ideas would be appreciated.
2nd, Is there a laundry spot remover that will get used diesel oil stains out of cloths? Like my T shirts or shirts and pants etc? Have tried a couple things and the stains are still there.
Thanks
Fraenk
Frank n Sandy
USN-Retired
96 Dolphin Diesel / 2002 Saturn
Fulltiming since 2004
Trailer Trash 2
Santa Fe Springs, CA
Posted: 06/26/08 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
I would think that diesel is in the oil family but very dirty, have you thought about denatured alcohol or a mineral sprits then a rinse down with the alcohol, I would try it on a area that you cant see before you do the area that has been damaged with soot. Lookt of clean absorbint rags.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
1996 Ford F-350,Clydesdale, 7.3 Turbo W/Banks
Pulling a Super Fine Montana 2980RL
sepisllib
Cresco, Iowa
Posted: 06/27/08 04:17am Link  |  Quote  |  Print  |  Notify Moderator
Similar issue on ours.
We used "resolve" spray on - very-very soft brush (like some use to brush their chrome wheels). It worked nicely - I scrubbed our entire ceiling that way and it's like new now.
God Bless
Bill
Bill W. Trammell
Wife - Judy
2001 Monaco Dynasty Chancellor
2008 Malibu 2LT toad
CaBoy
Junction City, OR USA
Posted: 06/28/08 02:44am Link  |  Quote  |  Print  |  Notify Moderator
To remove the soot, you might try Simple Green. It is a de-greaser and cuts engine oil & grease. I had a soot mark on the wall at the bed and Simple Green & a bit of elbow grease made it disappear. If the stains on the shirts have been run through the dryer, they are probably set but you might try Shout stain remover, have had some luck with that. Good luck.
The older I get, the better I used to be.
1997 Prevost by Country Coach
470 HP Series 60 Detroit / 6 SP. Allison
2005 Jeep Grand Cherokee Toad
Same Co-Pilot for 43 years
2 Boston Terrier girls, Scooter & Mia
JohnnyT
Goshen New York
Posted: 06/28/08 07:15am Link  |  Quote  |  Print  |  Notify Moderator
I have used 303 Cleaner and Spot Remover for Carpet and Upholstery to remove some oil and grease stains from carpet... Worked great...
The product is readily available from a variety of sources...
JohnnyT
franknsandy
Posted: 06/28/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Johnny T
Thanks, this is the kind of answer I was hoping to find. Will pick some up today, there is a supplier just a few miles down the street.
Frank
