sunnybrookbyrd
McKinney Tx
I am trying increase my tire knowledge. I'd like to know what others consider the best (Non-Chinese) brand of tire. My fiver came w/ Loadstar brand....already have had 2 tire failures. I've read several positive comments about Michelin XPS tires. Thanks, I appreciate all the help from this forum.
donn0128
Pronounced Ore-gun
Michelin LT235R16 XPS Rib.
ST rated tires have a speed rating and are not nearly as good as the Michelin LT.
Use the search function at the top of the page and type in tires and you will hours of reading. Most of it regarding the junk tires installed on trailers and the best replacements.
Donn
C.B.
APPLETON WI USA
Ditto to what donn0128 said
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
TORQSHIFT AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE
PRODIGY BRAKE CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
wayne_tw
South Dakota/Georgia
I agree with the post above. Buy LT tires, not ST tires.
kennethwooster
Perryton Tx USA
Michelin or Maxxis LT tires. Maxxis is much cheaper, and I've never had a problem. If I was rich, I would probably buy the Michelin, but I do like the Maxxis.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
FisHin2Dmax
Utah
I second the choice of Maxxis brand tires. I found the LT Michelins just a little too tall for my coach. NO problems with Maxxis ST tires! While I agree the best route is the LT Michelin Rib tires, I think you'll find that most LT tires are a little higher on the sidewalls. Those that must stay with the 80 series ST tires ( due to fitment issues), the Maxxis ST is not a bad choice!
2003 GMC HD 2500 CC 4x4 DuraMax/Allison
2008 Sundance 2900MK
Mountain Aire34
Greenlawn, NY 11740
What is the difference between ST and LT tires??
donn0128
Pronounced Ore-gun
Mountain Aire34 wrote: What is the difference between ST and LT tires??
ST= Special Trailer
LT= Light Truck
ST tires are rated to only 65MPH, have stiffer side walls than a P and are almost all made in China and are junk
LT tires can have speed rating limits, are made by a wide variety of manufacturers, are available nationwide at reasonable costs, have stiff side walls and are generally much more durable than the junk that are slapped on RV's by the manufacturer.
NC Hauler
Asheville NC
Micheling LT tires or their XPS Ribs...you won't go wrong with either of those. The Ribs are pricey, but MOST EXCELLENT trailer tires.
Jim & Kathy
2007.5 Chevrolet K3500DRW/CC/LB/LMM/D/A LTZ, Prodigy,Reese 20K hitch.
2006 HR Presidential Suite 37RLQ (4 slides).
2007 Mitsubishi Outlander XLS 4X4
Boxers: Sheba, 13...Buddy..1 yr.
USAF 71-75 Nam Vet
Cat320
Western AR
Also, the STs give a softer ride.
