RV.Net Open Roads Forum: Fifth-Wheels: Best brand of ST 235/80 R16 Tires
 > Best brand of ST 235/80 R16 Tires
JIMNLIN
Big Cabin, OK
Posted: 06/27/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Cat320 wrote:
Mountain Aire34 wrote:
What is the difference between ST and LT tires??
Also, the STs give a softer ride.
true but at a big long term reliability cost. The ST has a basket ball shapped sidewall that gives a soft ride BUT that basket ball shape has more sidewall flex which causes the tire to run hot. Also has the sidewall more suspect to sidewall damage. They seem to work better with light weight trailers but on heavier trailers a LT tire that the manufactor has recommended for heavy trailer use is the best for that long term reliability.
There are several good LT tires out here that make a better trailer tire choice than a ST tire.
Jim
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 06/27/08 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Most people want to keep up with traffic when towing and will drive between 65 and 70 to do so.
Most ST tires are only rated for 62 MPH max. and could blow from excessive heat when driving at 65-70.
The LT tire is rated at 75 MPH and gives a greater safety margin when driving at higher speeds.
What you should do is switch from the ST tire to the LT tire IF you can find one in your size.
I still keep the speed at 62 or below but the extra safety margin of the LT tire is nice to have.
Both my last two Newmars came from the factory with LT Goodyear tires and we have had no tire issues at all.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress
Picture of '93 Mountain Aire Story of it's death by fire and explosion
Mountain Aire34
Greenlawn, NY 11740
Posted: 06/28/08 07:15am Link  |  Quote  |  Print  |  Notify Moderator
G614 STR are made in China? They are only rated for 62 / 65 mph
?? Now you tell me. I just put them on last fall, and they were
expensive.
Kodiak5er
Posted: 06/28/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
expensive.
They are speed rated at 75 MPH and most of them are made in Kansas.
I will post how to tell where they are made from the DOT code on one side of each tire.
Check out the G614 tire here.
If you notice the G614 RST tire has the letters LT in the size (LT235/85R16 LR-G).
* This post was edited 06/28/08 09:08am by Kodiak5er *
Kodiak5er
Posted: 06/28/08 07:55am Link  |  Quote  |  Print  |  Notify Moderator
To find out where your tires were made go to this site and find the DOT code that's on only one side of your tire.
Immediately after DOT is a four letter group, the first two letters are the plant code. The last four numbers are the date code (2206 would be the 22nd week of 2006). If you have a 3 number date code, your tire was made before 2000 (226 would be 22nd week of 96 or 86 or 76).
Cox89XJ
Tennessee
Posted: 06/28/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Michelin Ribs, B G Goodrich Commercial TA's and Uniroyal make good LT tires fit for trailers.
DANWHITAKE
South Texas
Posted: 07/01/08 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
put on Michelin Ribs and you will sleep at nite with no worrys about tires tearing up trailer. imho dan
