RV.Net Open Roads Forum: Fifth-Wheels: 12V Batteries for 5er???
 > 12V Batteries for 5er???
mytime
Eastern North Carolina
Posted: 06/27/08 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I am thinking of installing new batteries in my 5er and was wanting to know which ones would be the best? I have 2-12V Marine type batteries now, was installed by the factory(Carriage). The ones now are around 5yrs old but still work, just not as good as they used to, and I need a new battery for my farm tractor and thought it would be a good time to take one of these from the 5er and replace both of them. So give me some good ideas on which battery would be best for the fiver. I do not have room for more than 2 do I would use the 6V ones??? Thanks
2005 Silverado/Duramax SB/4X4/ CC,16K Pullrite Slider, 2004 Cameo LXI 32.5 3 Slides.
George H
Washington
Posted: 06/27/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Marine battery from 5er may not work well in tracter, deep cycle does not have same cranking amps capacity as conventional battery.
Unless you do a lot of dry camping, two premium 12 volt marine/deep cycle batteries should be fine ( I like Interstate, myself).
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
Vulcanmars
Naples, FL
Posted: 06/27/08 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Some swear by the 6v set up. I don't buy it. I use 2 of the largest 12v deep cycle batteries that will fit. Read the labels for amps and amp hour rating. It is usually worth a few extra $ for more amps.
I've would have told you Delco batteries were best a few years ago but due to cost I stated using the Walmart brand. In the last ten years I have had very good luck with them.
Opinions will very.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Pullrite SG 16K
1st TH 02 Keystone Tailgator
fncampn
Gardnerville, NV
Posted: 06/27/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
See this article on replacing 12-volt batteries with 6-volt ones:
6-volt Batteries
Cold Weather Camping Mods
How to Do Just About Everything in an RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
smkettner
Posted: 06/27/08 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Costco has a good 12 volt deep cycle and carries the 6 volt golf batteries in my area. I have costco batteries in all my stuff and they work great. Lots of people use the 6 volt golf batteries and are very happy including myself. Just be sure you get golf batteries not a 6 volt tractor starting battery.
donn0128
Pronounced Ore-gun
Posted: 06/27/08 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Battery(s) are a strange thing. Depending how you camp you may need only one or you, like me may need a whole bank of them. If you only go to full hookup sites then a single 12 volt deep cycle from wally world is sufficient for all your needs and a lot cheaper to buy and maintain. If on the other hand you spend a large amount of time with no hookups then the more the merrier.
Donn
mytime
Posted: 06/27/08 09:30am Link  |  Quote  |  Print  |  Notify Moderator
So far for the past 4yrs have not done much dry camping, do use the SP's but usually have water and elec., but like things are going now I expect I will need some good batteries as may have to do wally rv park to make ends meet.
I was planning to check out Sam's, do not have a Cosco near by, was hoping someone would give me a name brand. I have used interstate before. Just need 2-12V that will handle the Slide outs(3) and jacks when not connected. We have to extend our slide(1) when we stop for breaks in order to get to the fridge.. Thanks for the responses...
smkettner
Posted: 06/27/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Interstate is a good battery but is not a battery manufacturer. For example US Battery makes both the Costco 6v and the Interstate 6v golf batteries. Costco is ~$75 and Interstate is ~$90 for the same battery different sticker lable. US Battery only lists one dealer in NC.
mgratner
Wherever I happen to be USA
Posted: 06/27/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
We have been fulltiming for over 3 years and have dry camped for as much as 5 days straight. Our unit has 2-6v bateries and by not going crazy with power we have not had any problems. I do check the batteries once a month and top off with distilled water as necessary.
Cigar Mike
2004.5 2500 CTD Dodge Ram Quad Cab Longbed
2005 CF29CK Crossroads Cruiser with all the options
sclark
Minnesota
Posted: 06/27/08 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned above, it depends on if you will be doing much dry camping. If not, then but the cheapest 12 volt battery you can find that will fit in the space. If you dry camp, then buy the deep cycle batteries that offer the greatest amount of amp hours. I am on year 5 with my Trojan T 105 batteries. Others use a pair of the 12 volt deep cycle batteries. You may want to check with a golf cart repair shop and price them there. Sams Club also sells deep cycle batteries. Many have had very good luck with them. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
