We just purchased a new 2007 Keystone Outback 26RKBS. The trailer seems to be relatively well designs except for one feature. The Fresh water tank drain valve is in between the axles. I can barely reach it when I reach between the wheels.
Has anyone ever moved the drain valve closer to the edge of the trailer where it would be easier to reach?
IrishCampers
2005 Ford Expedition King Ranch
Reese Weight/Sway Distribution Hitch
Yes, and I moved (entended in length) my low point drains and also added 1/4 turn valves as well - and probably my next TT project will be to reverse the fresh water tank drain to the street side of the TT where it will drain in to my evergreens and also replace that pitifully small drain valve with a 1/2" or larger quarter turn valve...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
I haven't done it but extending the drain lines is very easy with proper plumbing supplies. I would simply place some clear vinyl hose over the drain nipple and run this to wherever you want it, you will need another valve that you can buy at any hardware store, you may have to fabricate a bracket to hold it out of sheetmetal or...? You will then leave the valve on the tank open at all times.
NCH
edited 06/27/08 04:24pm by NCHornet1 *
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!! MY TRUCK OUR TRAILER
