JesLookin
Appleton,WI
I use 2x10s cut to 12" long, & some 3/4" plywood cut to match the 2x10s. They fit perfectly under the stabilizers or tires. I find that the shorter lengths are much easier to handle than a 4 or 6 foot piece.
2005 Sierra 285 BH
2003 Dodge 2500 Diesel, quad cab, short bed
wayne_tw
South Dakota/Georgia
You do not need all that wood. Why carry half a lumber yard with you? I have 10 pieces of 2" x 8" cut into 10" long pieces. If the trailer needs the low side raised up two inches, I just lay two bouads at the wheels and back onto the boards. If the trailer needs the low side raised up four inches, I lay one board perpendicular to the wheels, and another parallel to the wheels with one end of that board on the other making a ramp. I then just back up onto those boards and the trailer is raised four inches. If I need more height, I just make a new level of stacked boards between the wheels, and back up again. Way easier than carrying long lengths of lumber and way cheaper than buying those plastic squares.
boonie
Canada
I guess we have been very lucky, I've never had to level my unit in the 5 years camping so I don't carry anything anymore. The most I've been out so far is at most 1 or 2 degrees which is hardly anything IMO. When I did carry something I had 4 1/2 ton bottle jacks.
2003 Dodge Ram 2500 Quad Cab 4X4 Long Box 5.7 Hemi
2003 Coachmen Cascade 26RBS with a 14' Single Slide
The only practical use for that pistol is to fight your way back to the rifle you should not have dropped in the first place.
TexasBorn
Amarillo Texas
" The only practical use for that pistol is to fight your way back to the rifle you should not have dropped in the first place. "
I did not think you could have guns in Canada? But I love the way you think!
2007 Outback 29BHS TT
2002 F250 PSD, 4 Door, 4X4, 3.73
coptalker
Western Colorado
I keep a stack of 2x8's with a chamfer on the end. I've used as many as 7 or 8 under the low side. These vary in length from 12" to 20". I've also got a couple of bags of the yellow "Lego's" that I occasionally use. I boondock in some pretty remote areas so "level" is a very relative term. I'll get there but not on the first try. It's certainly not 'campground level' where I go.
Glen
2004 Dutchmen 27BG, Rocky Mountain Elk Edition
2002 Chevy Silverado 2500HD 8.1/Ally
2 boys, 12 & 14
a friendly black lab
a couple of decks of cards
a cold beer
Life is too short to sweat the small stuff.
smkettner
I have a single 10 pack of the yellow lego like blocks.
Have not needed anything else yet.
slowolf
Central Coast, CA
We use those orange lego-like blocks too. When we are camped in a level spot and don't need them, they are fun to stack and make things with
2005 Airstream Safari 28' w/slideout
2006 Ford F250 PSD FX4 Lariat w/ Tow Command
Hensley Arrow Hitch
lhuff
Marietta, GA USA
We use the orange plastic blocks that have holes through them. We tried the yellow ones for a few years (free with our first camper), but eventually they became brittle (from the sun I assume) and started breaking. We've been using the orange set we have now for about five years and they are as "good as new" so to speak.
Orange or yellow, they are light, easy to clean and dry, easy to store in their little pouch and inexpensive. For my $30 I'll replace what we have if the need ever arises with more plastic levelers.
Larry
Sir Buffalo
Long Island, NY
We had used wood. But we were camping once in Western PA and we had to raise one side of the trailer about 6". did not have enough wood. Went and bought the orange legos. Love them. Now we have two sets. I was always against them. But they are great. My dad laughs at me
Sir Buffalo!
2006 Zinger by Crossroads 27BHS
2007 Toyota Tundra Double Cab 5.7
cjoseph
WV
Funny you should ask.
This past weekend, I was drinking a beer and staring at my wheels with 2 x 6 blocks under them. I thought about letting some of the the air out of the tires on the high side next time and skipping the wood blocks.
Might work for an inch or two, maybe three? Of course, I have portable air to refill them.
Any thoughts.
Chuck, Heidi, Jessica, Nicholas & Tan Puppy
2008 3/4-ton Yukon XL, Flagstaff 831BHSS
Equalizer Hitch and Prodigy
