just me
Salt Lake City Utah USA
I saw on here where the electrical cord was coiled in a basket, and also a bucket to keep it under control, and not all over the place. I have a fellow camper that noticed mine coiled in a bucket and he said that was a good idea but might be hurting the out put on the other end.
What he was referring to was that there is resistance in the coiled cord like a wire wrapped around a nail and causing an electro magnet, thus resistance, and impeding flow of the electricity to its fullest.
What do you think?
fact or fiction?
I don't know so I am asking the Experts. [Ex being a has bin] [pert being a small drop of water]
95 Dodge CC #5 TST plate Flame Red/Silver
not totaly stock
2007 fiver
Tag Ma-haul [has been suggested for a name]
Note: Due to invalid formatting, all formatting has been ignored.
wayne_tw
South Dakota/Georgia
Fact. Actually, that is the basis of a transformer, wire coiled around itself creating resistance. However, I think the issue is minimal worst case.
ejforwood
Littleton (Denver) Colorado
The resistance in the line is there whether coiled or not. What is not there until coiled is impedance. Yes an ac current through a coiled inductor will cause a magnetic force to be induced into an iron core, ie. the nail, but your 25 ft cord will not loose potential because you coiled it up, or at least not to an amount that you can measure. At the point it might loose potential, you would also notice it giving off heat. Part of the confusion is that resistance and impedance are both measured in ohms.
A wiser man once said, "A little knowledge is a dangerous thing!"
Jerry
K0EJF
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
NCHornet1
Mt. Airy, NC.
I agree nothing to worry about.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
GSF
full-timing in North America
The problem is not with the electrical output. The problem with an coiled electrical cord is that coiling creates resistance and resistance creates heat. How much heat depends on a lot of variables.
George
97 Airstream Land Yacht
01 PT Cruiser Dinghy
Cappy - Pekinese Burglar Alarm
kaydeejay
SE Michigan, USA
GSF wrote: The problem is not with the electrical output. The problem with an coiled electrical cord is that coiling creates resistance and resistance creates heat. How much heat depends on a lot of variables. Not so much the coiling that creates resistance but it does concentrate any heat being generated in the cord when it is passing a heavy current.
Enough to be a problem - I doubt it, but enough to warrant a check at some point.
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
garry1p
Broken Arrow, OK, USA
Depends on the length of the cord and load.
If it gets hot then it is a problem no heat no problem.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
AlanB
Sierra Vista, AZ
Coiling the cord does not cause any problems. The wires inside the power cord are always out of phase and the induced magnetic affect cancels out. This is one of those "urban legends" that has been around a long time.
AlanB
2002 Holiday Rambler Imperial 40PKDD Cummins ISL
j2catfish
Newport, NC, U.S.of.A.
Coiled power cord will not make any difference as staed above - the magnetic field induced by current flowng in on the "hot" wire is canceled by the opposite polarity magnetic field caused by current returning to the source via the white wire. Now, if you tightly coil up your Citizen Band coax, or your satellite coax, you might notice some power loss.
JMO.
F350 Diesel; Teton 5er;
Native Texan - Transplanted Tar Heel
Retired USMC
Semper Fi !
GSF
AlanB wrote: Coiling the cord does not cause any problems. The wires inside the power cord are always out of phase and the induced magnetic affect cancels out. This is one of those "urban legends" that has been around a long time.
If you're going to spread erroneous information, do it on something that doesn't involve safety. Here's a link to an Electrical Engineering firm and their view of the subject. Read item #6.
Link:
And here's a link to a pamphlet from the state of Vermont, Division of Fire Safety. Link:
