RV.Net Open Roads Forum: Toy Haulers: Lighting Rodd
Search only in Toy Haulers
PsnRebel
On My Banshee, In the Dunes !! In SoCal
Posted: 06/27/08 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Due to the high rise in propane costs, I purchased and installed a 110v hot water heater rod. So now we have a gas and propane water heater. We are planning several trips to the lake this summer that have full hook-ups, so no extra cost to heat the water because we are plugged into power. So far it has worked very well.
BobWanderer
Perris,Calif,USA
Posted: 06/27/08 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Ours has one, only we have never used it.
Have to check that option out, only had hookups 3 or 4 times, but We will have to use it next time to see if it works.
Bob J
2008 GMC 2500HD 4X4 Dizzle CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
MEMBER AMA and CORVA
skipnchar
Topeka Kansas USA
Posted: 06/27/08 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
what is the difference?
SoCalDesertRider
SanDiego, CA, USA
Posted: 06/27/08 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
They make them run on gasoline now??
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Keily
Nova Scotia Canada
Posted: 06/28/08 04:35am Link  |  Quote  |  Print  |  Notify Moderator
I have had one for 4 years now and I think it is great, it sure cut down my propane cost. Now one tank will last me more than just one season, and I make sure that I fill up my propane tank when I an in the United States. In Canada, especially in Atlantic Canada, if you want to get filled up with propane at a service station, and most campgrounds, if they deliver that propane by volume and not weight, you will be charges as motor fuel and there is a much larger tax that goes with it. It doesn't matter that the one selling the propane can see that you have a gasoline engine, or a diesel engine, in your motor home , if they deliver it by volume( Liters), and your tank can't be removed from your rig and put on a scale and weighted, you will pay through the nose for it. The last time I filled up my propane tank, I was charged over $87.00 for it, at an Irving Service Station in Nova Scotia Canada. What really made me mad was the tax comission in Nova Scotia told me "they don't have to charge for it, but we know they do, just fill out a bunch of forms and sent in reciepts and we will give you the tax back." Like I said that was 4 years ago, I an still waiting.
Sorry a bit of topic, I had to vent , but an electric hot water heater is a much better investment than propane purchases in Canada.
bshortie
Ohio
Posted: 06/28/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I see there are basically 3 options to do this:
1. RV Hot Water Hybrid Heat By Camco
2. Universal RV Water Heater Hott Rod Kit
3. RV Water Heater Lightning Rod
They all look about the same price. Any recommendations? Do they all work the same way? I am leaning toward the one from Camco. Sounds like a complete kit, but am unsure how it works in comparison to the rods.
2002 Damon Challenger 348, F53 Chasis w/Triton V10
