RV.Net Open Roads Forum: Tech Issues: LED Lights
 > LED Lights
RollingRockTX
Keller, Texas
Posted: 06/29/08 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
sirdrakejr wrote:
Moved from 5th wheels to tech issues.
Frank
Boy....moving this thread killed it.
LOL
2006 Ford F250 King Ranch PSD
2008 Jayco Eagle Super Light 31.5BHDS, KC5PFG,
5th Airborne with SideWinder, Plugitright Stabilizers.
tioga_pass
CA
Posted: 06/30/08 12:26am Link  |  Quote  |  Print  |  Notify Moderator
I just posted this on another thread but the subject justifies the reposting:
I just replaced three of the incandescent lights in my RV with 12V THIN-LITE model 112 fluorescent fixtures (1" thick). The fixtures were an easy replacement that cost $35 each and took about 0.5 hours or less each to install. They use the same current as the incandescents (~1.4 Amps each) and output ~5X the light. Compared to the fluorescent fixtures LED replacement lights are not, at this point in time, cost effective based on the amount of light output.
narcodog
Georgia
Posted: 06/30/08 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I bought some from Randy at Best Converter. There is light and pattern difference between LED's but if you boondock they are the way to go.
Serena
US
Posted: 06/30/08 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Engineer9860 wrote:
I know that I have no issues with STT/marker/clearance light brightness, because I have had other drivers bellyache at me over the CB as to how bright my lights were to them.
Then as an Engineer and a Scout, I'm sure you can appreciate why I don't drive after dark any more. Imagine rolling at 75 MPH, and being suddenly blinded such that you can't see the road OR where to pull over. It doesn't get much better at 60MPH or 55 MPH, for that matter. So basically, your geekfest turns me into Stevie Wonder behind the wheel. Which IS pretty funny - well, except to Stevie and possibly whoever is behind Stevie...
Serena
I Know Where I Been, Cuz I Was There When I Went.
RollingRockTX
Keller, Texas
Posted: 06/30/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Very interesting point. Do you happen to know the color temperature of those CFL lights you put in? I am asking b/c anything less than say 3500K will have that "green" hue to it and for some folks, (My wife included) are very sensitive to that type of light.
tioga_pass
CA
Posted: 06/30/08 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
They were the "cool white" color (4100K?)
Engineer9860
Eagle Scout dad
Posted: 06/30/08 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I am confused here.........
geekfest?
I want to be seen, and being seen is a good thing if you are driving a 8~10 ton vehicle.
So my lights are causing a problem? If they are, I see no need to apologize for wanting to be safe.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
Lug_Nut
Newmarket , Ontario, Canada
Posted: 06/30/08 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
LED replacement lights was a topic sometime ago on the RV.NET Blog. You can view it http://blog.rv.net/2008/03/09/whats-new-in-rv-illumination/
'07 Newmar Essex 45' ISM 500 4 slides
Mousefart
New Jersey
Posted: 06/30/08 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
I used one of the LED arrays (on a PC board) from SuperBrightLEDS.com in my outside light. VERY bright. The amber lens takes care of the bluish light.
I have one of their older, not as bright arrays in the light of my stove hood. Makes a good night light.
superbightleds.com actually has some light arrays for RV/boat use that have a more natural, white light without the bluish cast now. Gonna get some one of these day to try out on the inside.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
jmanatee
Willington, CT
Posted: 07/01/08 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
I just received 3 of the 1156-PCB-WHP9 White LED Lamps in 3100k from Super Bright Legs and they are very impressive and they do not have that blue tint. I am very happy with them.
They are expensive but they only use 190ma and they have a very wide voltage tolerance 8 - 30vdc
Jon
Our RVing Web Site | Our Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
1992 32' Georgie Boy Swinger
 > LED Lights
