Greypops
How do I find a diagram of how to work on the release/pull handle to dump the black tank. I have not been able to empty the black tank. When I pull the handle it does not open and empty the tank. I dont know where to go to to try to fix the problem. Is there an online location I can go to to get a picture layout to know what part of the under side of the camper to remove to gain access or if I need to remove it.
jeepsucks
ontario
Have you removed the cap??
DW, Me, DD and new DD!
"Life isn't like a bowl of cherries or peaches, it's more like a jar of Jalapenos--what you do today, might burn your butt tomorrow......"
SidKaye
Mt Dora Florida, Montreal QC for the Summer
I have posted several times on "cable actuated" dump valves. You may look at these posts. Cable actuated dump valve posts
Sidney
edited 06/28/08 10:55am by SidKaye *
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
kmh3212
Georgia
Remove the panel directly below the pull handle under the basement. Once the panel is removed the valve and mechanism will be revealed.
SidKaye
kmh3212 wrote: Remove the panel directly below the pull handle under the basement. Once the panel is removed the valve and mechanism will be revealed.
They are not all the same but perhaps so on the Montana.
That is definitely NOT where mine is.
Sidney
edited 06/28/08 12:54pm by SidKaye *
richfaa
Ohio
Greypops.There are many models and years of Montana's you do not mention what year/model you have. On my 06 3400 the black handle is inside the convenience center. I would have to drop the underbelly directly under that handle and re attach the handle that probably has come loose. You will no doubt have to do the same with your year/model. You should be able to see the handle by removing several of the screws on that side.
06 Montana 3400. 08 Ford F-350 6.4L
HappyKayakers
Sebastian FL for the winter season
Do Montana owners have their own forums? You might ask there or contact the factory directly. The other option is indeed dropping at least a section of the underbelly to find out where the valve is. On my Bighorn, the valve is a few feet away from the handle. If you don't think the valve is operating properly, you really need to look at it while someone else is pulling the handle. It could just be a loose set screw. Or maybe the blade isn't closing completely so the water drains continuously. When you open the valve, you wouldn't see anything new coming out.
Joe, Suzanne (Kayak Queen), kayaks, bicycles and inline skates.
Dakota the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://www.happykayakers.com
cindik
Tennessee
Go Here. Lots of nice people who can probably help. You have to register to see most of the forum and ask questions.
IF YOU CAN'T STAND BEHIND OUR SOLDIERS, FEEL FREE TO STAND IN FRONT OF THEM
Our Photos
indyroadrunner
Brownsburg In
Richfaa speaks the truth. That is about the only way to check or fix the valve and Rich I know has been there done that.
06 GMC 2500HD 4x4 Duramax 6 sp Allison Tranny
06 3400RL Montana w/Trail Air King Pin
01 Bichon CEO
TopSail Hill Preserve cult member Now member of St Andrews SP Cult
jackandh2o
Golden Valley, Arizona
What cindik said. The montanaowners website is really great.
You will probably get much feedback from people that have your same year and model unit.
Ray
