RV.Net Open Roads Forum: DO ANY OTHER GMC 6.0 LITER GAS ENGINES HAVE THIS PROBLEM
Search only in Tow Vehicles
 > DO ANY OTHER GMC 6.0 LITER GAS ENGINES HAVE THIS PROBLEM
woodrow
Nooksack WA
Posted: 06/29/08 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
no cure...fought that battle for years, the 8.1 6.0 and some 5.3's all do it, seafoam it thru the pcv valve once and a while and it helps some...pistonslap.com...kind of a negative site but there is some good info on there.
'07 2500HD Classic D/Max LBZ 6Spd Ally Westin nerf's,5'' mbrp turbo back
PPE airbox mod,Hijacker 24k,Prodigy,Magellan nav,'06 Cougar 314,265 Bfg Km's,Chrome MB 16x8's,Firestone bags,level command compressor kit.Lund Fisherman 1700
My Garage Photobucket
Stefan
Calgary, Alberta, Canada
Posted: 06/29/08 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Google 'piston slap' and you will find a LOT of info on it, all from no harm at all, to this is the end of the world.
Also, if you do a search on it here, you will find a lot of topics too, seemed to be a big topic about a year or two ago...
Stefan
2003 Chevy Silverado 1500HD, 3.73, 4x4, Crew Cab, 6.0L (loving it!)
2003 Layton lite 232 BH
8.1 Van
Millstone NJ
Posted: 06/29/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I guess I have the only 8.1 with no piston slap. My 8.1 van sits for weeks at a time between startups and is as quiet as my Scion xB.
FKA PSDExcursion
2002 Chevy Express LS 3500 8.1 155" WB passenger van 3.73 posi (GT4/G80)
41 Ft 2003 Thor Citation 41-ZBSR TT w/ Hensley Arrow
snownyet
Western NY
Posted: 06/30/08 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
I had a kid at a taco bell drive thru tell me I needed to add oil to my brand new avalanche in 2002 cause it rattled so bad, I traded it with 25k on it. Piston slap is and has been an issue with GM's since they replaced the 350 and 454.
2007 Montana Mountaineer 307RKD
2006 Chevrolet 2500 4x4 crew Duramax/allison
woodrow
Nooksack WA
Posted: 06/30/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
your 8.1 could never do wrong anyhow sits for weeks but tows all the time with bogus mileage reports?..outpulls a diesel, never slaps(BS) and is worth more than a new caddy. The slapping is a common issue with the gen 3 gm gassers, and always will be. mine pulled great without an issue for tons of miles. Resale is a huge killer though, keep it and you will be OK, they run like crazy but selling them is a Mess! clickety clackety clock....
Engineer9860
Eagle Scout dad
Posted: 06/30/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
This is like the 300th time I have posted this.......
My 8.1L doesn't slap, my wife's 6.0L gasser slaps for about 15~20 seconds after initial start up.
There are starting to be 100s of these 1999+ engines that are reaching 150,000~200,000. I am yet to hear of any early failures due to piston slap.
Chicken Little wake up and smell the coffee, the sky just aint fallin'.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
dragr1
Alabama
Posted: 06/30/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
My '00 6.0 slaps with 110k miles, I had an '00 5.3 with 275k miles, slaps but never had any engine problems, had a '99 5.3 with 325k miles-no engine problems, have another '04 5.3 with 150k miles and no problems, an '05 with 125k miles-no problems, and lastly an '01 6.0 with 155k hard miles and no problems. They all slap, but all they still run good and most of those vehicles have led hard lives in the woods, mud, and towing everyday.
1991 Allegro M31 Basement
1985 4Runner Rockcrawler
2000 Suburban 2500 4x4
2007 Toyota Tacoma Crew Cab TRD 4x4
2002 Lexus IS300
http://community.webshots.com/user/dragr1
http://s42.photobucket.com/albums/e335/dragr1/
Thunderbolt
North Branch, Mn USA
Posted: 07/01/08 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Some of the 350's had piston slap as well. I have one and it started at about 150K and hasn't gotten any worse. The thing is is on mine in the winter it sounds like the pistons are going to come through the block until the engine actually warms up. The truck now has 258K on it and the pistons are still in it and it still rattles until warm and then it is quiet.
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM
98 K1500 4x4 heavy duty 1/2 ton
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
250,000 miles still purrin' like a kitten
8.1 Van
Millstone NJ
Posted: 07/01/08 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Your brain is clickety clackety . I am down in Florida with it and it runs perfect.
silversand
Montreal
Posted: 07/01/08 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Can anyone here point out a bona fide published document indicating that 'piston slap' has been the cause of early engine demise in any of the Vortec engines sited (these engines with several billion owner-accumulated miles in play already)? I think not.
Use your truck, change the oil as indicated, and don't worry about the few minutes of noise till she's warmed up
Cheers,
Silver-
Silver
