RV.Net Open Roads Forum: Fifth-Wheels: How to tell if Roto-Flex is working?
 > How to tell if Roto-Flex is working?
bayoubelle
Amite, LA
Posted: 06/28/08 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
We got a Roto-Flex hitch on our new camper as a standard item. How can you tell if it is operating properly? There still seems to be a lot of chucking while towing the camper. Our only comparison is our previous camper, which was considerably smaller and did not have a Roto-Flex. While driving the hitch doesn't seem to flex or move any differently than the hitch. We are just trying to determine if there is an issue that we need to tell the dealer about. Should we be seeing any movement from the Roto-Flex while we towing?
GEAUX TIGERS!!!
luvlabs
Frederick, MD
Posted: 06/29/08 08:20am Link  |  Quote  |  Print  |  Notify Moderator
These are fairly new and there doesn't appear to be too many out there. When you look at the design, the only fore-aft damping you might get is if your fifth wheel is going up and down and pivoting on the plate (one of the criticisms of the Trail-Air pin box as well).
The only two pin boxes that I know of that really address fore-aft movement are the Demco Glide-Ride and the Morrhyde pin box. I have no experience with the Demco but I can tell you that the Morrhyde works exactly as advertised.
I guess you decision might be to live with it or upgrade. Before you do anything, try adding more weight to the front of the fiver - you can get chucking if you are too light as well.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
kennethwooster
Perryton Tx USA
Posted: 06/29/08 10:41am Link  |  Quote  |  Print  |  Notify Moderator
If it is doing the job, you should feel the difference. When we went to the Mor Ride, we got rid of all the chucking and bouncing.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
