RV.Net Open Roads Forum: Tech Issues: Dometic Fridge not cooling on propane
 > Dometic Fridge not cooling on propane
obrn59
Jacksonville, FL
Posted: 06/28/08 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Turned on the propane and then turned the fridge to auto. The light indicated switched to gas. The fridge never got cold and the light indicated when checked again, attention was need. Why wouldn't the fridge get cold with propane? And yes, there is propane in the tanks. No electricity.
Hopefully it's something simple, (operator error)
Steven, Lesa and Taylor
2004 Potomac 5333RL
F350 Dually 4X4
RPFAN
Poughkeepsie NY
Posted: 06/28/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Is the trailer plugged in? If not' if battery runs low, circuit board will not function.
2) When was the last time it ran on gas?
Rich, Fern, Bethany, Justin. 2005 Ford F450,Lariat, 6.0 PSD,CC,DWR,4WD, Air Hitch, 100 Gallon Aux fuel tank.
2007 Cedar Creek Silver Back 35L4QB
Our "Condo in the Woods"
Leave no roller coaster unridden!
obrn59
Jacksonville, FL
Posted: 06/28/08 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I can't remember the last time it ran on gas. The trailer was not plugged into electricity. Before we were heading on a trip I wanted to cool down the fridge in order to place some food in there for traveling. So it wasn't even hooked up to the truck.
Maybe the battery thing is the issue
Thanks,
ScottnSherrie
Augusta, GA
Posted: 06/28/08 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto the good 12V to the fridge. Easy to check with a multimeter.
If not run on propane for a while, it can take several cycles of trying to start it before the lines are bled and propane flows the burner.
If both of the above are good, time to start troubleshooting the fridge. Multiple good sources for that on the web plus helpful folks here once you have some info to report.
When was the last time you PMed (preventive maintenance) the fridge. Dirty or our of adjustment ignitor can cause issues as well as a dirty burner.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
obrn59
Jacksonville, FL
Posted: 06/28/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
WOW, I didn't know you have to PM the fridge. We purchased used about 2 or so ago. Thanks for the help
Where would I find PM information on the fridge?
mike4947
N. Syracuse, NY
Posted: 06/28/08 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a site with manuals for most fridges: http://bryantrv.com/docs.html
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
