RV.Net Open Roads Forum: Technology Corner: Comuter Reboots Itself
 > Comuter Reboots Itself
chiefward
Covington, GA
Posted: 06/29/08 06:55am Link  |  Quote  |  Print  |  Notify Moderator
My old computer (which gave to my grandson)has for some time frequently reboots itself. Usually it will freeze before rebooting. There does not appear to be a pattern or special program running to cause this. The operating system is windows XP. I've run virus and spyware checks many times, but it still reboots.
What do I need to look for??????
2000 Fleetwood Terry, Model 275J EX
2003 Ford F250,V10,6.8L, Super Duty, 4WD, Quad Cab
16K Reese Hitch w/slider
Polishnurse
Schodack, NY
Posted: 06/29/08 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I would open it up and clean it out, check the fan and make sure thats work. Could be over heating and shuting down.
Then start to look software. Bill
Teacher's Pet
SD.. Fulltimers. Goshen IN summers
Posted: 06/29/08 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Try hitting any key and see if the screen comes back. I had a virus recently on my notebook that gave me a "blue screen of death", asked me to press a function key, then rebooted. Except the reboot was not real. By touching any key on the keyboard, the screen I was working on came back for about 20 minutes, then the process would start again. We found out my McAfee was out of date since a recent reformat, that took care of the problem.
At the same time I was getting a "warning" on my desktop that the computer was infected and I should install Anti-Virus or Spybot software. McAfee did not remove this problem. This was actually wall paper that had been installed by the intruding program.
'06 Phaeton 40' QSH
'03 Ford Sport Trac
Scottiemom's Pet
Husband to Dale
2 Traveling Scotties
RV.net Rallies 11, Other Rallies 7, Escapades 5
2005 F/T Class
Our Travel Blog
Where are we?
ReadyToGo
Minnesota
Posted: 06/29/08 07:24am Link  |  Quote  |  Print  |  Notify Moderator
About a 90 percent chance that it is overheating and about 10 percent that it is a virus. Do all you can to correct an overheating problem and then you might look into a problem with the power supply.
ReadyToGo
Minnesota
Posted: 06/29/08 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Teachers pet: What you real problem is, is that you responded to an malware popup which you should never do. Than you installed some software the popup recommended. Another major nono. Do a google to see how others have gotten rid of the malware. A lot of antivirus programs will not get rid of these as they aren't virus but a legitimate but questionable program.
jauguston
Bellingham, WA
Posted: 06/29/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
It may be the hard drive dying. My HP DV4000 started doing that and tech support led me through some tests and said the hard drive was bad.
I never buy extended warranties but for some reason I did on this laptop. It has paid for itself three times over!! I have three months of a three year extended warranty left and it was shipped back to me Friday. Third trip in for repair.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
275 RV injectors
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
crazyhorse
San Diego
Posted: 06/29/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
anytime you have system reboot by itself , normally this could be cause by a bad memory dimm. Your programs depending on which one uses up high end memory causes the fail dimm to fail.you can to replace the memory or try to remove one dimm module at a time and try to reproduce the failure..
Scottiemom
South Dakota/Indiana
Posted: 06/29/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
No, he didn't respond to the program. We know not to do this. The problem was while he was running antivirus, he had not picked up the most recent due to his recent reformat. Once we got that downloaded and installed, it did find the malware and removed it. We also ran Adaware and Spybot S&D. His machine is clean now. The newest version of McAfee did find it along with another worm he had picked up. These are not virii, but PUPs (potentially unwanted programs).
All is well now.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
Mom to 2 rescued Scotties
Bailey and Neal
2006 Tiffin Phaeton 40' QSH, 4 slides (Phaeton Place)
2003 Sport Trac Toad
Fulltiming since retiring in 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
Scottiemom
Posted: 06/29/08 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Normally any time I have had overheating issues, it doesn't re-boot. It shuts down and won't restart until it cools down. I did have one fan on a motherboard once that went out and the machine would re-boot, but wouldn't run.
Dale
JasonD
Annapolis, MD
Posted: 06/29/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
My 1st guess on an old computer is a failing power supply.
2008 42' Foretravel Nimbus CE
2007 Chevy Tahoe toad
