nosticks
St. Petersburg, Fl.
I have been looking at a 5 year old Winnie. The owners were heavy smokers. It has not been in use for a few months. When you open the door, the whole thing smells like a Sports Bar Lounge. Stale cigarette smoke has penetrated everything. Someone is bound to say there are plenty of others out there, but I know the history on this one and the layout is exactly what I want. So, does anyone know of a product(s)that will eliminate, not mask, but totally eliminate the stench.
NoSticks
www.dschraml.com
dav5942
Stuart, FL
No, you will never get it completely out! Although OderCide(Walmarts) in your steam cleaner will help for cigs but will not work for cats!
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,lifted Jeep(s) in tow, Hog Valley Florida(a diamond in the rough),'09 Alaska again!
2007 Tour Alaska Fishing '08 Tour Grandchildren Newmar Mid Engine
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
cigarette odor removal
this is a link to things that may help.
/ang
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004. My only home.
My Homepage and Rv pics press here
JohnnyT
Goshen New York
There sure has been a lot of discussions on how to rid a motorhome of odors associated with smoking... Ozone generators to chemical warfare to absorb and camouflage the smell... Unfortunately not too many reports of taking a motorhome like you have described and getting rid of the smell...
Virtually all of the fabric, cushions, mattress, carpet, even some of the wood will have absorbed the smell.
If you are only contemplating having to clean and sanitize I think you will be disappointed with your efforts... If you are planning a major interior re do then you might achieve your goal.
I think I would keep looking.. Sorry
JohnnyT
tom_kat
way upstate new york/lake george area
first clean then repaint or varnish to seal in the oders on wood, change all the fabric and carpets would help but probably not get rid of all of it but would help a lot.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
eaw46
Regina Sask. Canada
If you can rent an Ozone generator it will help a lot.You should be able to get one from a rental place. You hook it up and leave the Motor Home for 10 to 12 hrs and it really will help. I do not think anything will completely remove the smell but it will help. Eddy
Eddy from the Great White North
1997 Triple E Commander 35
Rex & Shirley
Bastrop, Texas
We used a commercial product called Ozyme back when we had our Inn. It worked well enough to clear a room of smoke odor so non-smoking guests didn't notice. I also accidentally eliminated all the smell from the flowers just befor a big wedding reception with it. Steam cleaners, as mentioned, work best for nasty smells in fabric but reality is all stuffed things like pillows, couch and chair cusions may need replaced. Scrub or setam the headliner too as smoke rises and the roof will be a lot worse that you think. Ozyme can be purchased at resturant or janitorial supply stores or maybe on-line now.
Rex & Shirley S.
4 big dogs in a
Gulf Stream FriendShip
mpfireman
Cook County Il
Go to your local Ace Hardware store, and pick up a product called FRESH WAVE. Give it a try, for about 10 to 15 dollars you probably will solve your problem. AND save a lot of $$$$.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
Jim & Joan
Milton, WI
ODOBAN works well. Sams have concentrate and Walmart has premixed
hershey
Albuquerque,(fulltime) NM, USA
Would the owner let you try the above mentioned remedies before you buy? What does he have to lose? You might try that.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
