92DakotaHD
Indiana
I am curious. I had it pounded in my head early to never tow more than 1500 lbs or so with the OD on. Or really if it hunted for the right gear and was bouncing back from OD to 3rd to just lock-out OD.
On that note I read a lot of people asking about why wasn't this vehicle or that vehicle in OD and why is it revving so high? Is this no TOW in OD rule just a Dodge thing? (I learned it while on Dodge Forums) I would think nearly all transmissions are locked in OD therefore not able to slip and take pressure off the gear and the nature of OD makes it more fragile. I can see maybe and HD truck having an OD capable of handling it but not most of us with smaller TV's.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
Pioneer 17T4 Just PERFECT for Two!
Gone Racing!
A newbie, any tips please share!
Gale Hawkins
Murray, KY
I learned the $$$ way in the Blazer with the 4L60 transmission if anything is hooked to the hitch to stay out of OD. After the last transmission in hilly two lane roads not towing I tend to stay in 3rd to reduce hunting and shifting.
With the MH with the 4L80 GM transmission I tend to stay out of OD if any degree of TC lock up is hunting or the transmission is changing gears very often because a MH is like fully loaded/same as towing where you have anything on the hitch or not.
I have yet to see any fuel savings from OD IF any hunting is going on with the transmission. We all ran one gear below OD not that long ago and did just find.
tom_kat
way upstate new york/lake george area
i believe running in OD wears out most automatic transmission befor there time when loaded or towing something ,a lot of the OD transmissions are rated way lower then the older 3 speeds were but they expect them to the same job as the 3 speed HD models.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
DKean
Mays Landing NJ.
My 06 F350 dually diesel with 4:10 rear pulling my 32' cedar creek does a fine job in overdrive with the tow haul. I weighed the rig and it is 19,900+ gross.
wilber1
Abbotsford B.C. Canada
I tow a 10K trailer in OD all the time with my 01 Dodge CTD. With 4.10 gears I would be deaf if I didn't.
"Never trust a man who has not a single redeeming vice" WSC
mpfireman
Cook County Il
With my 98.5 Ram, Cummins powered, I Tow in OD all the time. But if entering parts of our country with mountains, or are rather hilly, the OD is off. My fiver is a Sunnybrook in the 10,000 # class.
You have to use common sense when towing in OD.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
Campnfuls
Hilt, CA
DKean wrote: My 06 F350 dually diesel with 4:10 rear pulling my 32' cedar creek does a fine job in overdrive with the tow haul. I weighed the rig and it is 19,900+ gross.
Unless my transmission is hunting for the right gear I use OD. Like DKean I have a 6.0 PSD (2006 E-350) with 4.10 but only towing a rig that is 7,600 gross. My TV performs almost like it's not even there.
I want to leave this earth quietly in my sleep like my grandfather and not like the hysterical, screaming passengers riding in granddad's RV just before the big crash.
264SRinPA
northeast Pa
With the newer fords you can't disengage the OD. Just push the tow/haul and let the tranny do it's job. OD will kick in at about 60mph.
crashpilot
Green River, WY
I've got 2 overdrives and I don't have a problem with using either of them while towing.
As long as you don't let your transmission hunt for gears making it shift over and over and over, there shouldn't be a problem.
Straight Board -
2008 Chevy 4X4 Z71 Crew Cab K2500HD LTZ Duramax/Allison
2005 Jayco JayFlight 31BHDS
2007 Kawasaki BF 650 4X4i Camo (mine)
2007 Polaris X2 500 EFI Deluxe (hers)
The mountains of Wyoming as my backyard.
Powder River, Let 'er buck!
GSS0816
Chestertown MD
I tow in OD with my 3500 GMC DMax....no problems.
