RV.Net Open Roads Forum: General RVing Issues: Quickie Flush Works !
 > Quickie Flush Works !
K&R
Oklahoma
Posted: 06/29/08 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Just installed a quickie flush on both the gray and black tanks this weekend.
They really do work!!
Id recommend them to anyone who is tired of using the wand sprayer.
woolfy
Saint Charles Mo.
Posted: 06/29/08 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Were do you get these
2007 Itasca Spirit 31' Ford V-10
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Mark Twain
K&R
Oklahoma
Posted: 06/29/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
I got em at the local camper dealer as Im sure you can but if not check online.
They are worth it !
tenbear
Northern Vermont, USA
Posted: 06/29/08 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Tornado is similar to Quickie Flush except that the sprayer spins inside the tank possibly giving better coverage, not to start another "which flusher is best" arguement.
2004/5 Four Winds Dutchman Express 28A, Chevy chassis
Subaru Impreza Outback
K&R
Oklahoma
Posted: 06/29/08 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I looked at both pretty hard but went with quickie because it doesnt have any moving parts to break. Either one is a heck of alot better than sticking the wand down the toilet! I also am glad I put one on the gray tank as there was alot of crud in it also.
OlderThanSand
Tollhouse, Ca
Posted: 06/29/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Amen to that! Next on my list is a Tornado
2002 4x4 Super Duty PSD
2006 22' Carson Titan
2006 Polaris Ranger
2007 Suzuki LTZ 400
2007 Honda TRX 250EX
1995 model dune crazed granddaughter
NCHornet1
Mt. Airy, NC.
Posted: 06/30/08 04:09am Link  |  Quote  |  Print  |  Notify Moderator
I agree either one is better than the wand, even though the wand will clean the stubborn you know what, better than the rinsers. I would not replace the Flush King with one of these though. I have posted this often but one more time won't hurt. My buddy and I both bought new TT about a month apart, his was a little fancier and came with one of these rinsers. He bragged to me how I just had to install one. Well I looked at them and at the tanks on our TT, I see these being worthwhile if you had one at each corner of the tank and maybe a couple in the middle as well, but this isn't practical. There is no way one of these rinsers can be affective down at the other end of the tank, or even across a wide tank like my 48 gal. So we took our first trip, I told him to flush with his new "gizmo" and I would use my FK. When he was sure his tank was clean we hooked up the FK and did one back flush, you should have seen the look on his face when he saw what came out. He then went out and bought a FK and uses them both. I am not saying the FK is the end of all tank cleaning tools, I still break out the wand down the commode for stubborn junk and for just a good high pressure cleaning every 3rd to 4th time I dump.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
tenbear
Posted: 06/30/08 06:18am Link  |  Quote  |  Print  |  Notify Moderator
There is no reason you can't use the Quickie Flush or the Tornado as a Flush King. Just leave the drain valve closed and let the flusher fill the tank, then open the valve. Presto, everything runs out just like the Flush King. No need to have both.
CHV_FRK
Black Jack, MO
Posted: 06/30/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
That's what I have done, even yesterday. It does take a while longer though since it's alot more restricted. We sprayed and sprayed....then closed the valve, filled, and dumped 3 more times with only the last time coming clean. Definately do this where you have your own sewer hookup.....or at midnight at the group dump station!
Dana and Natalie
2008 Chevy Silverado 3500HD LT DRW CC LB 4x4
2008 Jayco 35RLSA 38'9"
Hornet28BHDS
Parker, PA
Posted: 06/30/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reccomendation!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
