In that case, your problem is lime. Also remove the aerators from the faucets and shower head and clean them out. Replace any screens as needed. You'll be getting little rocks in them from the lime deposits over time.
BirdSongPlace wrote:
ernestfortier wrote: If they are made of real glass, not plastic, you can use oooo-steel wool. Just make sure that you keep the glass wet at all times when rubbing with the oooo-steel wool. The description sounds like a soap scum building up on the glass. The steel wool will also remove alkai from glass.
Thanks, I'll try the steel wool. Mine isn't soap scum. It is something a lot tougher to remove than that. Here in southern Calif we have really hard water. Because of that we have had soft water service to take care of the spotting in the shower and dishwasher. My dishwasher is fine but the shower is looking pretty bad.
If all the above fails, try a single edge razor blade. Some of the above is going to scratch the glass. Your door might be plastic and the harsh chemicals have caused permanent damage.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
