RV.Net Open Roads Forum: Travel Trailers: backing up over a curb
 > backing up over a curb
rathr-b-campin
MICHIGAN
Posted: 06/29/08 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I recently moved into a city and now have curbs. I have a good spot to park the trailer, but i would need to back it up over a curb. I'm not sure how the trailer would handle this. Does anybody have any ideas or can tell me how they do it.
2004 coachmen 248TBG "SPIRIT OF AMERICA"
2003 Ford F-150 supercrew:
Airforce one intake
3" magnaflow cat-back si/so exhaust
Check out my truck at Fordtruckworld.com
Gdetrailer
PA
Posted: 06/29/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
depending on the approach, you can use several 2x10s stacked to ease the trailer over the curb. You will need these to be several lengths say 3 ft and 2ft and 1ft. Stack the short ones on top of the long ones. To make it better have one end cut with a angle (45 degree or less).
ernestfortier
Palmdale, Calif.
Posted: 06/29/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
The TT could handle it easy. The problem is the tires. It is easy to break the steel belts in the tire when backing over curbs. When backing into the curb, the whole weight of the TT is pushing on the rear tire, you can see a lot of flex on the rear tires, then the weight is suspended on only two tires, overloading them until the second pair is firmly on top of the curb.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
Huntindog
phoenix arizona USA
Posted: 06/29/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of trailers out there with weak spring hangers (don't ask me how I know) so it could cause a problem there as well as the tires. Probably should make some sort of ramp
Huntindog
2001 Wilderness 26H
Onan 4.0 Microquiet\26 gal. tank
72 hours of run time!
T-145s
2001 Silverado 3500 CC D/A
EQUALIZER Hitch
Juiced, K&N air filter
Banks 4" exhaust
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
DadToFourBoys
Posted: 06/29/08 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Here are some curb ramps that are made for getting RVs up curbs.
skipnchar
Topeka Kansas USA
Posted: 06/29/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you have the necessary ground clearance and take it slow you will have no problem with the curb. Have you looked at some of the chuck holes on the highways? They make your curb seem pretty tame when you consider hitting one of them at 60 MPH or so.
Fulltimers
Anywhere, USA
Posted: 06/29/08 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
I used to use a 4X4 against the curb and a 2X4 against that. Worked well.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
aftermath
Washington State
Posted: 06/29/08 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that your sewer connection will clear. Mine is very low and I would worry about tearing it off if the curb was very high.
2008 Toyota Tundra, Double Cab, 5.7L V8
2004 Starcraft 21SSO
Equalizer Hitch
Prodigy Controler
rhillx4
Huntington Beach ,CA
Posted: 06/29/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
We built ramps to get over our curb. Our curb is pretty high.
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
NCHornet1
Mt. Airy, NC.
Posted: 06/30/08 03:01am Link  |  Quote  |  Print  |  Notify Moderator
If you are worried just use the ramps as already stated.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
