RV.Net Open Roads Forum: Travel Trailers: backing up over a curb
 > backing up over a curb
5rFozz
SoCal
Posted: 06/30/08 03:35am Link  |  Quote  |  Print  |  Notify Moderator
If you've got boards or legos for leveling, use those.
1992 Ford F350 7.3 diesel crewcab dually
2001 Komfort 26FS
tvman44
Southwest Louisiana
Posted: 06/30/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Put a couple of 2 x 4's to roll over to ease the transition.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Hornet28BHDS
Parker, PA
Posted: 06/30/08 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Make some sort of ramp to use to get up over the curb.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
RichandLiz
Connecticut
Posted: 06/30/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Watch everything under the trailer from the rear to the tires. Make sure all clears the curb. as said, use blocks of wood or the like to help gentle the curb.
dodge guy
Chicago, western subs.
Posted: 06/30/08 10:10am Link  |  Quote  |  Print  |  Notify Moderator
What type of curbs do you have? we have curbs, but they are low and rounded. others, such as city curbs are high and squared off. these are the ones that will cause problems.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
rathr-b-campin
MICHIGAN
Posted: 06/30/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Our curbs are pretty high. I wish i had the low ramped curbs on my side of town like they do on the other. I'm worried about dragging my sewage lines on the curbs because i think they would hit before the tires get to the curb. I was just wondering what everybody else did.
2004 coachmen 248TBG "SPIRIT OF AMERICA"
2003 Ford F-150 supercrew:
Airforce one intake
3" magnaflow cat-back si/so exhaust
Check out my truck at Fordtruckworld.com
BLDMAN
Missouri
Posted: 07/01/08 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I just drive over mine slowly.......my TT set low so I had to watch my sewer lines, the fiver is plenty high. Our curbs are about 5 inches high. They are straight up and down but have a slight angle back. Have been backing over them for years without problems with the trailer or trucks tires. Just be sure of clearance.
Jeff and Barb two sons Jeremy and Jared one daughter Heidi one grandson Gabe
Two Labrador Retrievers Shadow and Otis and her majesty, Miki the Boston Terrier
2006 Fleetwood Prowler 275CSK Fifth Wheel
1999 F350 PSD dually
SPRey
Orange County, Kalifornia
Posted: 07/02/08 12:06am Link  |  Quote  |  Print  |  Notify Moderator
The curb at my house is angled for drainage such that...4x6 timber (from the stabilzer) are the perfect "stair step" to move from street to sidewalk. I just move the timber block after backing the TT...as we know the TT & TV wheel bases are not the same.
My TT is parked on a pad adjacent to my driveway--but the "sloping driveway cutout" does not extend to that portion of my pad...so it's all curb for my TT & back tires of my truck. Nice and easy...and never a prob!
Tim & Sue
Gerry (GSD) & Jammer (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 37 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
Red Wine anyone?
rathr-b-campin
MICHIGAN
Posted: 07/03/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
We got the trailer home and in place today. We ended up coming from the driveway at about a 45 degree angle and going across the front of the house. It worked out pretty good. I think it would have cleared the curb ok, we actually drove the left tires over the curb. But we got her parked in her spot and didnt lose any pieces.
ddav15
Chino, CA
Posted: 07/04/08 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I have been backing mine over the curb for several years using 2 pieces of 4x4 tapered off 45 degrees with a table saw. That leaves 2 or 3 inches the tire has to climb. I have seen the curb ramps on the above link and they look like the best solution.
