RV.Net Open Roads Forum: Travel Trailers: NewbiePropane Switchover Question
 > NewbiePropane Switchover Question
krazymatt
NM
Posted: 06/30/08 11:37am Link  |  Quote  |  Print  |  Notify Moderator
When one tank of propane runs out, does it automatically switch over to the other or how does that work? I know there is a valve-like thing with an arrow pointing to a certain tank. If anyone could please explain to me the process to change from one tank to the other I would appreciate it. Thanks..
New Mexico
2008 Forest River Puma 26RLSS
2008 Dodge 2500 SLT Big Horn QC Cummins 4x4 6Spd Auto, Exhaust Brake.
Easy-Lift 1000 WD hitch.
2400IS Yamaha Generator
Bonefish
Midland, TX
Posted: 06/30/08 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it will automatically switch over to the other tank if both tank valves are open.
I have stopped using the auto feature because I ran out on both tanks once. You need to check on them often and sometimes you use more fuel than others. I now leave one tank closed and use one until empty switching the tanks manually. I take the empty one in to fill as soon as I switch tanks.
Bonefish
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 06/30/08 11:49am Link  |  Quote  |  Print  |  Notify Moderator
LP Regulator
The regulator is the heart of the LP system. LP gas is under high pressure in the bottle and the regulator reduces this pressure to allow safe use with the appliances in recreational vehicles.
The lower pressure is distributed to the appliances. The arrow on the automatic gas regulator will always point to the gas bottle in service. When the red flag appears in the inspection glass, this indicates that bottle is empty. In systems without automatic changeover, the arrow should be then turned toward the other bottle and the empty filled as soon as possible.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
EnglishBulldog
Maryland
Posted: 06/30/08 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
As a fellow newbie...how does one know when one of the tanks is empty? Mine is hooked up to electric while parked at the house.
windriderjr
Massachusetts
Posted: 06/30/08 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
You know the tank is empty because the green thing on the regulator turns red.
I put an in-line gauge on my tanks, too.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
Hornet28BHDS
Parker, PA
Posted: 06/30/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
On our TT, you have to manually change the tanks.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
92DakotaHD
Indiana
Posted: 06/30/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
It knows because it probably has some kind of pressure valve in it.
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
Pioneer 17T4 Just PERFECT for Two!
Gone Racing!
A newbie, any tips please share!
MFinCA
San Francisco Bay Area, CA
Posted: 06/30/08 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Here is the explanation of how it works:
LP Auto Changeover
MFinCA
2004 Homestead Settler 255RS
1999 Chevrolet Suburban 2500
NCHornet1
Mt. Airy, NC.
Posted: 06/30/08 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
I just changed/filled my tanks today. You have been told correctly, if you have the auto changeover valve and leave both tanks open the system will draw from the tank the lever is pointing towards. When that tank is empty the valve will show red and start drawing from the other tank, when you see the red you flip the valve to the other tank and if it has gas in it, it should go back to green. This allows you to fill the other tank and put it back inline with the valve open. I hope this makes sense to you.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
EnglishBulldog
Maryland
Posted: 07/03/08 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Follow-up: I went out and checked my tanks. I don't have anything special; just two tanks, two hoses leading to one grey metal round thing. Do I need an auto changeover thing or do those tank indicator sticker things work???
