RV.Net Open Roads Forum: Travel Trailers: NewbiePropane Switchover Question
 > NewbiePropane Switchover Question
MitchF150
Puyallup, WA
Posted: 07/03/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, it sounds like you do not have the auto switch over regulator...
Do you need it? No. I don't use the sticker things.. If I have a question on how full the tank is, I just pick it up and stir it around. If I don't want to remove it from the trailer, I'll pour some hot water on it and feel for the cold part. Up to the cold is approx how full it is.
I like my auto switch feature! It's saved me a couple of times of running the furnance at night and running out of gas on one tank sometime during the night.
Since I only go weekend camping, I'm turning on and off the tanks within 3-4 days anyway, so I have a chance to check them. I've never gone thru a full tank in a 3-4 day weekend, so as long as I have 'some' in one tank and a full one to switch to, I'm good.. I get the empty one filled when I get back home, so I don't forget!
Works for me, but I can also see the other side where people want to know the minute a tank runs out..
Good luck!
Mitch
1997 F150 XLT, 4x4, SuperCab, ShortBox, 5.4, 3.55 gears, Prodigy, EAZ-Lift WD hitch, Autometer Water/Trans temp gauges, 180,000 miles (GVWR #6250 GCWR #12500)
2003 Prowler Lynx 722F (GVWR #5000)
Bucky Badger
Madison, WI
Posted: 07/03/08 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I just put an auto change over on yesterday. Mine use to draw from both tanks at the same time, so when I ran out........I was OUT. What a PITA it was.
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
www.titantalk.com
2007 Forest River Salem 27RB LE
Nights camping 08 (15)
Rallies/Gatherings
IL
WI
summutt2002
(somewhere in the mountains of Utah)
Posted: 07/03/08 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Hornet28BHDS wrote:
On our TT, you have to manually change the tanks.
Are you sure? On a 2006? Interesting. The switch on the regulator is simply a manual way of telling which cylinder you are using. I don't even use it, just use a magic marker on the tank with date of refill or need to refill.
Great wife, 3.1 dogs and no money..LIFE IS GOOD
As of 7/14/08.....'01 Excursion Ltd 7.3L PSD (Juice w/Attitude, s&b intake, 4" turbo back exhaust..the SES light is always on) easily pulling a '06 Prowler 260RLS, Equal-i-zer, Prodigy
Luvnevryminutofit
Springfield, IL
Posted: 07/03/08 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
For the rest of us newbies - how high up the tank would the cold level be if the tank is full? Would it be half way? Three quarters?
I do not have the auto switchover regulator and mistakenly opened both valves. I think I now have two half full tanks!
Mark & Kim
Kaylee, Jake & Justin - da squids
'02 KZ Sportsmen 2505 - Quad bunks & rear queen slide
'05 Chevy 2500HD Crew Cab 4x4 Duramax
JJBIRISH
BUTL;ER, PA, USA
Posted: 07/03/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
a full tank is about 80% full in volume...
I didn't think they still came with manual valves any more...
I really like the auto-switch, it only takes about 3 seconds to check it, if I don't do that I figure I deserve to run out...
mine seems to only run out and change over between 2 and 3 AM (maybe some kind of conspiracy), I think that's enough of a reason to like them right there...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
campinginthewoods
Rantoul,IL
Posted: 07/04/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
EnglishBulldog wrote:
As a fellow newbie...how does one know when one of the tanks is empty? Mine is hooked up to electric while parked at the house.
when it runs out and theres no flame...... I have a manual change over and when I run out I know I'm empty and change over otherwise I don't worry about it But once I change over I always fill the empty one asap......
"It Bears all Things,Believs all Things, Hopes all Things,Endures all things......Love never Fails...."
Gene&Ginny
North Kingstown, RI
Posted: 07/04/08 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Follow-up: I went out and checked my tanks. I don't have anything special; just two tanks, two hoses leading to one grey metal round thing. Do I need an auto changeover thing or do those tank indicator sticker things work???
I had that and would only open one tank. Sometimes I would forget from one trip to the next which tank I was using and end up with 2 low tanks! I put in an automatic changeover so I now have a pointer to show me and then refill the empty as soon as it changes over and I move the manual pointer to make the indicator green again.
Gene & Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
