RV.Net Open Roads Forum: General RVing Issues: Air Filters
 > Air Filters
3girls
NH
Posted: 06/30/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
How often should I change the air filter in my truck to optimize gas mileage. Is once a year good enough??
2003 Dodge Ram 1500 Q/C 4x4 4.7 V8 / 3.55 2004 Surveyor SV-291 4480# Dry w/options:R[red]
Note: Due to invalid formatting, all formatting has been ignored.
javaseuf
Southern Cal
Posted: 06/30/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
That depends on what type of driving you do. If you can see dirt on the filter, I smack it on the driveway and then blow air from the inside of the element out.
I do this a few times a year or until the filter doesn't get clean any more.
If I go camping with the PUP into the boonies on dirt roads, this maintenance gets done more often.
Now this service intravel is much longer than the local Jiffy Lube that thinks my filter should be changed at every 3,000-mile oil-change!
I remember one time when my local Jiffy-Lube type of place suggested I have the automatic transmission fluid flushed and changed. I said sure, go ahead and do it.
When I got the bill, I took them out to my truck and asked them where that transmission dip-stick and pan-filter was since I HAVE A MANUAL TRANNY!!!!!
( CROOKS!!)
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
smkettner
Posted: 06/30/08 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
30,000 or check the manual.
bill h
el segundo
Posted: 07/01/08 08:49am Link  |  Quote  |  Print  |  Notify Moderator
A Filter Minder can pay for itself by avoiding unnecessary filter changes.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
portscanner
Georgia
Posted: 07/01/08 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
( CROOKS!!)
You better check and make sure that you still have coolant in the radiator and not ATF!!!!
One beautiful wife, one beagle, two brittney spaniels
2005 F250 SD Diesel 6.0
2007 WW SL2805
Web Site
kellem
shenandoah valley
Posted: 07/01/08 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a K&N high flow filter and the book says every 100,000.
Once a year is fine for paper filters.
 > Air Filters
