RV.Net Open Roads Forum: Dinghy Towing: Mileage on HHR
Search only in Dinghy Towing
 > Mileage on HHR
trickto322
Chuckey, TN./Sioux Falls,S.D.
Posted: 07/03/08 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Are you pulling the right 2 amp fuse? I have a 2006 and I have 0 miles added while towing.
kjet1600
Hood River, OR Park Host
Posted: 07/04/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I pull the correct fuse. 2 amp #8, I have dropped a couple down in the console area, so I have a fuse switch on order. I will pull all the fuses if it will help. Still waiting to hear back from my dealer.
fishboat1
southern ca
Posted: 07/04/08 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Fuse should not make a difference. Re check owners manual and make sure ignition key is in the correct position. Good luck waiting for the dealer response.
Mike H
2007 Allegro Bay 34XB FRED
2002 Dodge Dakota 4 wheel drive Toad 4.7 v8
Four Winns fishing boat
RandD
Carrollton, TX, USA
Posted: 07/06/08 07:02am Link  |  Quote  |  Print  |  Notify Moderator
KJet - Sorry to hear your dealer is as mis-informed as mine. The HHR is fully 4-down towable and does not rack up mileage. I have about 5,000 towed miles on mine and none registered. FYI - my dealer was so HHR ignorant that I have moved to a different dealer for service. The HHR is a great toad!
Randy & Diane
WB5TEY
'05 Lexington 255DS with '06 Chevy HHR following close behind
Dynamic Duo 2
Fulltimers - Currently in Arizona
Posted: 07/06/08 07:33am Link  |  Quote  |  Print  |  Notify Moderator
We have an 06' HHR and have towed over 15,000 miles - no problem with mileage adding on while towing.
Kevin & Susan "Dynamic Duo"
06' Country Coach Inspire "Genoa Designer Series"
Luigi The Traveling Dog & Boss
ThunderingQuiet
In Your Mind
Posted: 07/30/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
kjet1600 wrote:
Did not see anything in the owners manual on it.
If your HHR is a 2006, you will find reference to 'Dinghy Towing' on Page 4-38. That page also references Page 5-38 for which fuse to pull.
When I pulled of the cover to the fuse panel, the fuse diagram is upside down compared to the actual location of the fuses in the fuse block.
clnhse
louisiana
Posted: 07/30/08 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I had my tech install a switch in the compartment on top of the dash. The switch cuts power to the panel. No dead battery, no miles. We also installed extra light bulbs in the tail light housing so we did not tap into the factory wiring. My shop has done several of these for my customers. Last week I had them install a M&G brake system,,,,,sweeet.......
mtaylor05
Troy,MI.
Posted: 07/31/08 04:56am Link  |  Quote  |  Print  |  Notify Moderator
NO mileage adds up on mine, are you sure that you are not turning the key to far. There should be no lights on the instrument cluster.
The Traveling Taylor's
2004 Infinity 36A
2008 Chevy HHR toad/brake buddy
kjet1600
Posted: 08/13/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I did install a switch, so no more pulling the fuse. I have also done the extra bulbs in the tail light housing, seems to work ok. Did not want to cut into factory wiring. I am sure the key is in the right position, so next trip I will be double checking everything. This is an 08 HHR Panel, should not make a difference. Thanks for the input. It is hot in Hood River, Or.
 > Mileage on HHR
