RV.Net Open Roads Forum: Tow Vehicles: back of pickup bouncing while backing
Search only in Tow Vehicles
 > back of pickup bouncing while backing
Hannibal
Gas Station
Posted: 07/02/08 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Kangaair is right. I owned a '98 Dodge Cummins with 4.10 and 5spd. It would do the same thing in reverse or forward if I launched in 1st towing our 5th wheel and didn't give it any throttle when I let the clutch out. I always tried to slip the clutch as little as possible but, at 80k plus miles, the clutch was worn and chattered. Spring wrap up in reverse was always a balance of throttle and clutch. Same with my '94 Ford gasser 5spd. My '84 Isuzu diesel 5spd 4.10 had the original clutch at 288k miles when I traded it. I probably could have slipped the clutch a little more and got away with it...
'05 2500HD Dodge 5.7L Hemi 5spd auto/3.73 SLT. 91k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins
'07 KZ Jag 28JFSS.
riddellr
Belleville, IL, USA
Posted: 07/02/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with my truck and replaced the clutch only to still have the same problem. Mine ended up being a tired left leg . After paying more attention after the expensive new clutch, I noticed that when I released the clutch in reverse, my left leg would shake a little. Once the bouncing started, my leg would amplify the problem by bouncing the clutch pedal while backing uphill into the driveway. I solved the problem, by resting my left heel on the floorboard while actuating the clutch with my upper foot/toes. Now when I notice the truck starting to shake, I simply lower my foot to the carpet and all is well. I sure wish I had discovered that before the clutch replacement.
Take Care,
Bob
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/02/08 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a chattering clutch to me.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
NCHornet1
Mt. Airy, NC.
Posted: 07/03/08 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Back up in 4 wheel low but don't lock the hubs, this will allow you to make sharper turns.
If you end up getting a clutch get a good one like Luke or Southbend, and you will see a huge difference.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
NGRRFan
Colo. Spgs., CO
Posted: 07/03/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
So far no one has mentioned or asked what kind of surface the tires are on. My truck will bounce in reverse as the tires make and break traction . This doesn't happen on concrete or asphalt just on the dirt/rock roads found in alleys or campgrounds, especially if it is a bit of an uphill backing maneuver.
My solution is to put the truck into 4 Lo and let all the tires move the rig rather than depending on just the rear tires doing all the work.
Rich, Kim, and
Tobi the rescued dog
Oreo (waiting for us at the Rainbow Bridge)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
BenK
SF BayArea
Posted: 07/03/08 10:40am Link  |  Quote  |  Print  |  Notify Moderator
4x4 on good traction conditions is NOT a good idea, especially when
turning in a tight radius.
Unlocking the hubs is the best way when on good traction conditions.
Your U-Joints will appreciate that...
-Ben Picture of my rig
dixoncider
socal
Posted: 07/03/08 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I remember the good old days when diesel was $4.70 gallon
94 Ram 2500 Diesel
06 Ram 3500 Mega CTD Jake Brake
07 Pioneer 26BHS
coolbreeze01
Redding, Ca
Posted: 07/03/08 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
claybird wrote:
Thank you to everyone who took the time to respond! It looks like it is more than likely clutch chatter. I've also spoke with some local mechanics who agree. It seems like this is a fairly common issue. I did try backing up a hill in 4 wheel low and that solved the problem, but I can't turn as sharp. Will be taking the family for our maiden trip this weekend (even with $4.70 diesel), can't wait!
thanks
Sounds like you figured it out. That low range is handy. Have fun
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
