RV.Net Open Roads Forum: Best place to measure vehicle weights (Calgary, Alberta)
 > Best place to measure vehicle weights (Calgary, Alberta)
Prasa
Calgary, Alberta
Posted: 07/01/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Hi (near) Calgary residents
Want weigh my trailer and tow vehicle. What is the best place to do this (in Calgary)?
My friend suggested 'dump sites' but not sure whether this is the best place.
Thanks
Prasa
Dick_B
Palos Heights, IL USA
Posted: 07/01/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Any truck stops in Calgary?
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
eubank
Angel Fire, NM, USA
Posted: 07/01/08 09:14am Link  |  Quote  |  Print  |  Notify Moderator
I've often used gravel pits, which usually sell gravel by weight. They often have a large-scale weighing facility. Check the phone book and give some of them a call to find out.
L
http://forum.aardvarkrv.com/blog/
JFG
TN
Posted: 07/01/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Road King Travel Center or Huskey Truck stop both have CAT scales
Fred
Dale M
Calgary
Posted: 07/01/08 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Hi. Flying J in the south end of the city has a scale.
Road King truck stop on Barlow trail also has one.
I have used the scales on the highway,one is just south of the city
and the other I have used is the one just west of the city 1/4 mile past the petro gas station on the #1 highway
Dale M
2006 GMC 2500HD D/A 4x4
2007 Wildcat 29RLBS
Hijacker 16k Slider
Prodigy Brake Control
Honda EU2000i Generator
Wherever I happen to park
Posted: 07/01/08 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Any certified scale that is NOT a bridge scale can be used
It must NOT be a bridge scale though (A bridge scale is above ground on a bridge you want a scale that is flat and level with the ground around)
If it is a "Segmented" scale you park, fully loaded, with one axle on a segment (the other axle on another segment)
You then pull off and around and park with just one side on the scale, same way (Front wheel on one segment and the other on another segment)
(NOTE: you can also do both measurements with one side on and one side off)
Axel weight - wheel weight = other wheel weight
If it's a "Single" scale. then you are going to need 4 weights One for each wheel
OR.. If you attend an FMCA rally (if you are a member) or a number of other rallies you might hook up with Aweigh-We-Go... They bring the scales to you
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
Posted: 07/01/08 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
The last time we were in Calgary - a couple of years ago there was a provincial do-it-yourself scale about 1 KM south of the city limits on the Mc leod Trail - on the west side. Just south of Pine Creek Rv park ( as it was then).
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2001 Silverado 2500HD shortbed
wonderful lifetime travelling companion/spouse
CRMW
Calgary, Ab, Canada
Posted: 07/10/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
The Husky at Barlow & 32nd has a scale.
