dennislanier
Georgia
While sitting here recuperating from sciatica/back injury, I have thought of a question about the front landing gear. Has anyone ever tried attaching a spring from the "foot" of the landing gear to the top, which would raise the inside of the leg when you pull the pin. I realize there is not a lot of weight involved, but you are in an awkward position all bent over when pulling the pin with one hand while grabbing the foot and raising it manually. Looks like that might be "back saver" for us old folks, but wondered if anyone had seen or tried it before.
DO N DAT
Antioch, Ca
How would you lower the foot then?
1999 Ford F350, 7.3 Diesel, 2003 Triumph 365L
Rheevs
Minnesota
Try here goto bottom of page
5 TH WHEEL LEG LIFTERS
NO MORE DIRTY HANDS, DAMAGED
FINGERNAILS OR BRUISED FINGERS
MAKES RAISING FRONT LEGS EASY
PERMANENT INSTALLATION
MADE FROM HIGH DENSITY PLASTIC
$15.00 per pair (2) plus shipping
They are not springs but look like they would make things a little easier.
Life Is A Journey Not A Destination
Good Luck !
Vicki and Ed
2009 Cedar Creek 34 RSLA
Trail Air Hitch Coupler & Equa-Flex Flexible Equalizer
2008 GMC Sierra 2500HD, Ext Cab, D/A, 4x4
"Ride-Rite" Air Bags & SuperGlide 18K
dennislanier
Georgia
DO N DAT wrote: How would you lower the foot then?
Guess what - I hadn't thought about that. I suppose you could unhook the spring from the top, then let it drop down and re-hook it, but that might be as much trouble as manually raising the leg. any more ideas from anyone?
johntank
Oxford, Ms 38655 USA
I had a trailer that had springs inside the legs, yes it is nice to pull the pin and the foot snap up, but the down side was it made it hard to extend the foot when needed.
slides
Piedmont of NC
To play off of what Rheevs had linked to. I installed an eye bolt in the bottom hole of inside leg to grab and raise the inside leg. No dirty hands cost about $3.
03 Ford F-250 Super Duty Super Cab SB 4 x 4
6.0 Turbo Diesel 3.73 Gear
Torqshift Trans
'06 Rockwood 5er 8283SS
Use And Promote CB Channel 13
CC-skipjack
Portage, MI
I put a large ring through the bottom hole. Then, I use a metal rod with a hook in it, (similar to the one used for awnings), and just hook into the ring and lift. If the angle of the pull is shallow, it does want to bind but works well 50% of the time.
Charlie K
CC-skipjack
2000 Cedar Creek 30RL / 2001 GMC 2500HD
bobmeel 65
Petal, Mississippi
I was wondering about this myself so go to this site and take a look.
www.rvcamperaccessories.synthasite.com
last
edited 07/04/08 05:20pm by bobmeel 65 *
View edit history
