RV.Net Open Roads Forum: Beginning RVing: Where is the drain hose?
 > Where is the drain hose?
ceeyahd1
Camarillo, CA
Posted: 07/01/08 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a 96 Alpenlite 34RL last year and never used the onboard water for anything because all the camping we did was full hookups, my question is: where is the hose or drain for this tank so I can clean and drain the tank? I looked everywhere on the bottom but no 100% sure I know what I am looking for.
What the ratio of bleach & water to sanitize the tank? it is a 100 gallon tank
rnr42005
melbourne, fl.
Posted: 07/02/08 12:24am Link  |  Quote  |  Print  |  Notify Moderator
the drains for ours is under the bottom drawer in the kitchen cabinets, one each for the hot and cold.
tryhere. you should find the answers to many questions that we have all had at one time or another.
rnr42005
melbourne, fl.
Posted: 07/02/08 12:25am Link  |  Quote  |  Print  |  Notify Moderator
luck would have it
Dimondale (Lansing), MI
Posted: 07/02/08 01:31am Link  |  Quote  |  Print  |  Notify Moderator
Your best bet is to locate the fresh water tank. From there do some searching. If you can see the tank from inside the TT (under dinette or couch, or through a storage compartment) than look around that. if you can not see the tank (concealed under the TT) Than look from a spout hanging under the TT, usually near where you would fill it. It should be located in one of those areas.
Dave.
2004 Chevy Silverado Z71, Ext. Cab 5.3L
Prodigy Brake Controller
Husky WD Hitch
Dual Cam Sway Control
2007 27' Salem BHBS (Bunk Slide/Super Slide)
NCHornet1
Mt. Airy, NC.
Posted: 07/02/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Ia gree find the tank and you should be able to find the drain. It may look like the shut off valve on a cooler, just turn the lever and the water drains out. If you never used it there may not be any water in it.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Hornet28BHDS
Parker, PA
Posted: 07/02/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
That's great advice for you to follow!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
racefan1965
Redding, Ca.
Posted: 07/07/08 12:35am Link  |  Quote  |  Print  |  Notify Moderator
Look for a red handle between the wheels on the door side of the trailer. That's where the fresh drain was on another 96 I recently saw.
Rick
Rick, Shirley, Lacy, Misty and 2 dogs(Shasta & Baylee)
1999 Dodge 2500 Quad Cab 4X4
1984 Alpenlite24 5er
1988 Coleman pup
2006 Champion C46540 RV plug ready genset
